TS-808 clicking or popping noise
Started by THEMBONES, July 30, 2010, 08:51:51 PM
THEMBONES
Hello every one, I recently built a TS 808 using the layout from tone pad and I ordered my parts from small bear. The pedal sends clean sound in the on or off position but I get no distortion when it is on and there is a constant heart beat or loud thump. I tried resoldering the ic socket and some other joints that looked dull. I also tried flipping the ic around but still no result. Here is my part list for the build. It is my list directly from the web site. also i made the pcb my self using the tone pad laout. Any help is apreciated. Thanks guys
Socket, Transistor, Mill-Max TO-5
Alpha 16mm Single-Gang, Reverse Audio & "W", Solder Terms
(20K "W")
       Alpha Single-Gang 16mm, Solder Terms, Linear & Audio Taper
(100K Audio)
(500K Linear)
   Capacitor Silver Mica 500V 10 pf. - 150 pf.
(47 pf.)
   Capacitor, Panasonic ECQ-B 470 pf. - .047 mf.
(.047 mf.)
   Capacitor, Panasonic ECQ-B .15 mf. - .22 mf.
(.22 mf.)
   Capacitor, Panasonic ECQ-V .01 mf. - .1 mf.
(.1 mf.)
(.022 mf.)
   Capacitor, BC Components, 1 mf. 63V
(BC Comp 1 mf. 63V)
4    1404    Capacitor, Electrolytic, Radial 16 V 1 mf. - 100 mf.
(1 mf.)
   $0.20    $0.80
2    1404    Capacitor, Electrolytic, Radial 16 V 1 mf. - 100 mf.
(10 mf.)
   $0.20    $0.40
(47 mf.)
   $0.20    $0.40
4    2006    Transistor 2N3904
   $0.25    $1.00
10    2208    Diode 1N914
   $0.13    $1.30
2    1507    IC JRC4558D
   $0.45    $0.90
5    0900    1 Ohm to 100 ohms - Individual
(100 ohm)
   $0.15    $0.75
5    0901    120 Ohms to 1K - Individual
(220 ohms)
   $0.15    $0.75
(470 ohms)
   $0.15    $0.75
10    0901    120 Ohms to 1K - Individual
(1K)
   $0.15    $1.50
5    0902    1.1K to 6.2K - Individual
(4.7K)
   $0.15    $0.75
5    0904    43K to 220K - Individual
(51K)
   $0.15    $0.75
10    0903    6.8K to 39K - Individual
(10K)
   $0.15    $1.50
4    0905    240K to 1 Meg - Individual
(510K)
   $0.15    $0.60
4    0906    1.1 Meg to 22 Meg - Individual
(2.2Meg)
   $0.15    $0.60
4    0904    43K to 220K - Individual
(100K)
   $0.15    $0.60
3    0806    Black Fluted
(Black Fluted)
   $0.75    $2.25
1    0600    Jack, 1/4 in. Mono Switchcraft #11
(Switchcraft #11)
   $1.85    $1.85
1    0602    Jack, 1/4 in. Stereo Switchcraft #12B
(Switchcraft 12B)
   $1.89    $1.89
1    0619    9-Volt Battery Snap
   $0.35    $0.35
1    0621    9-Volt Battery Clip
(9-Volt Battery Clip)
   $0.62    $0.62
1    0612    Jack, DC Power, 2.1 mm Metal
(Jack DC Power 2.1 mm Metal)
alotawatts
How about some close-up gut-shots....?
jasperoosthoek
The parts list does not really help that much ;). Can you measure the voltages on the pins of the IC and transistor? Reversing the IC might destroy it altogether (is that what you mean by flipping it around?
If you get a clean sound when it's engaged you might want to look at the connections to the bypass switch.
Good luck!
[DIYStompbox user name]@hotmail.com
THEMBONES
Thanks for your replys, I am sorry it took so long to respond. I am not getting any voltage to the transistors or the IC. I was getting 9.46 volts on all of the IC pins yesterday. I did some touch ups yesterday and I think I broke it. I am thinking its time to build another one I have all the parts to make a second one if need be but I am hoping i dont need to do that. I am unable to post pictures at the moment but I will do my best to get some up here.
