Modded my ts9
Started by clamup1, August 08, 2010, 08:28:20 PM
clamup1
i modded my ts9. doing the ts9 to 808 mod. need the ic and im done. also did one of keeley's mods. i dont know which one. i need two caps for that one. so far its sounds sweet. it upped the bass and highs. im enjoying playing this pedal. its too bad i cant get one i built to work. oh well. Rock On
clamup1
hey ran into a prob. took out the ic and put in a socket. put in a 4558 and when you turn up all the knobs you get a low growl sound. other than the growl there is no distortion. i dont know what i did but i screwed it up good. any help would be helpful
clamup1
i was doing these two mods
http://www.musicianshotline.com/archive/monthly/pedal_power/0603.htm
http://www.tonepad.com/photoessay.asp?photoEssayID=9&sequenceNo=1
the photoessay one i got the resistors in with no prob. changed out the chip ran into prob.
the musicianshotline says to change out the 1 uf np to 1 uf. which way will the new caps go in + side to the chip or other way around.
clamup1
heres the photo.
i scratched some places to see if the flux was shorting out the pedal. but that didnt work either
Kearns892
I'm not really sure what you are asking. Try reading the debugging thread stickied at the top of this page and post in that format to get some help.
