"Little Angel" - Super Simple PT2399 Mini Chorus
Started by frequencycentral, August 09, 2010, 08:13:21 AM
p_wats
Hey guys, I tried a perf/p-to-p layout for this, but it's only my second time ever going from schematic to layout, so I screwed up somewhere and I get nothing but a faint hum. Can anyone see anything glaringly wrong at a glance?
culturejam
Pins 3 and 4 should be grounded, not just connected to each other.
Pin 4 is the analog ground, and if it ain't grounded, you don't get sound.   :icon_mrgreen:
p_wats
Quote from: culturejam on August 23, 2010, 06:12:35 PM
Thanks for the catch. That's just a drawing error though, as I actually did ground pin 4 when I perfed it...so there's probably something else keeping it from working.
culturejam
I think I see the problem.
The 470K resistor should connect directly to pin 6 of the op amp. You have it connected to pin 7.
JKowalski
Quote from: joethugs on August 16, 2010, 11:49:07 PM
no wonder your etching technique is superb because you design them in illustrator which is vector based as opposed to photoshop pixel based..
Photoshop does vectors too! Even on my now-very-old photoshop 7 that can't install on windows 7.  :'(
Quote from: my7of9 on August 16, 2010, 03:04:35 PM
Quote from: frequencycentral on August 14, 2010, 06:50:23 PM
.....and the PCB apparently will fit in a 1590A! This might well be my excuse to try my hand at a 1590A build. solderman? danielzink? valoosj?
I don't wish top be a party pooper but...
I have to report that I do not believe this will fit into a 1590A.
The board is exactly as wide as the outer dimensions of the enclosure. While you could perhaps lean the board I do not believe you would have room for the footswitch and especially jacks with a leaning board.
I will say it will fit a 1290 very nicely however.
If someone can prove me wrong...(Daniel Z. ?) .. I will certainly tip my hat to you!  :icon_biggrin:
:o Shock and disappointment! So I've shaved it down to fit. I believe a board 13 pads wide will fit in a 1590A. The only compromise it that the connection for Depth pot lug 3  has moved from the edge of the board to, err, elsewhere. If anyone wants to etch one for me.......... :)
Pigyboy
Wow. Great work Rick.
Has any one tried this with a bass yet?
My friend Dan McNay is playing with Ronnie Montrose and The Frank Hannon Band and asked me yesterday of an interesting bass chorus. Any cap replacements to make it more bass friendly would be great.
Rick, do you mind if I use the layout to make him one?  I will get pictures for you.
And you'll have to admit, I'll be rich as shit
I'll just sit and grin, the money will roll right in....
                                                            - FANG
Pigyboy
[/quote]
[/quote]
I can etch a few of these and send you one next week no problem.
                                                            - FANG
Quote from: Pigyboy on August 26, 2010, 03:50:38 AM
Earthscum has used it with bass and seems to like it!
That's what it's here for!
Quote from: Pigyboy on August 26, 2010, 04:03:23 AM
:icon_biggrin:
I just tweaked that layout slightly so C8, C9 and C10 can be bent over to lay flat if need be, it will show up in my post above when photobucket gets it's shit together to finally refresh.
Govmnt_Lacky
This may be a noob question but...
If I copy the layout from Frequency above, are there any special changes I need to make in order to "size it right?" Or, is it already properly sized to populate with components?
Quote from: Govmnt_Lacky on August 26, 2010, 08:24:06 AM
Scale the PnP to a .1 inch grid in photoshop. An ICs pin spacing will match the grid when correctly sized. Is that what you mean?
I see my 'slightly tweaked' 1590A layout in my last post still hasn't refreshed in photoshop, so here's direct links in dropbox:
http://dl.dropbox.com/u/967492/LAC%201590A%20PCB.gif
http://dl.dropbox.com/u/967492/LAC%201590A%20PnP.gif
culturejam
Here's a little layout note:
C11 is really close to D1 (which must be mounted vertically) and R19. So it either needs to be a smallish cap, or leave some slack on the leads so you can bend it over and lay it flat over R19.
Yeah, there's not much room there (sorry!), I didn't want to make the layout bigger just for the sake of one pesky diode. I figured people might instead mount the diode on the copper side or even directly to the DC socket. This would also allow C11 to be bent over on it's side for extra 1590A squeezage. That's what I'll gonna do.
culturejam
By the way, Rick, I've played around with several values of resistors where the two 220Ks are located. I ran out of 220K, so I took the opportunity to socket those spots and test it out. I can say for sure that any value between 150K and 275K will work in either or both of those positions. Waveform and min/max speed will change, of course, but several alternative values will work in a pinch.
Also, different op amps make a subtle, but noticeable, change in the LFO waveform shape.
Govmnt_Lacky
Quote from: frequencycentral on August 26, 2010, 08:33:49 AM
I do not have Photoshop. Any other way to ensure it prints out to correct size?
nordine
Quote from: Govmnt_Lacky on August 26, 2010, 09:28:46 AM
the hard way: trial and error  ;D
i print three tries with marginally different sizes, then pick an IC socket and see on which one it fits better
You can also do it in MS Publisher, I just tested it. I made a grid 0.254mm (= 0.1") and scaled the pad spacings to that. Worked a treat.
Govmnt_Lacky
Quote from: frequencycentral on August 26, 2010, 10:14:49 AM
I also do not have MS Publisher. As you can tell from my login, I work for the government. They do not give us cool software tools like MS Publisher. Any other ideas? Sorry to be a pain. Can anyone tell me a % to shrink this down to in order to get the sizes correct?
Any other ideas would be appreciated.
Govmnt_Lacky
Sorry about my first reply.... Here goes again...
radio
Hi
I m at work too(but in Central Europe). I just "open with" PAINT , did a "resize" to 50%.
I printed out and mesured,seems to be ok with 2.54 mm distance from hole to hole.
Regards Jean-Marie
Keep on soldering!
And don t burn fingers!
