Plastic Enclosure for a Power Supply.
Started by Canis guitarus, August 11, 2010, 03:49:44 AM
Canis guitarus
I have built a reasonably simple 9v power supply for my pedals inside a plastic enclosure and am now troubleshooting a slight hum problem. Is the lack of sheilding likely to be an issue in a power supply circuit? Thanks for your time.
brett
Hi
the hum is more likely to be due to poor voltage regulation or earthing issues than no/poor shielding.
Also check for line loads and radiative sources, such as flickering flouro lights.
cheers
Brett Robinson
SpufuZ
#2
I have biult several of this one:
http://www.generalguitargadgets.com/projects/24-power-supplies/135-regulated-power-supply
I have biuld that circuit in both alu and plastic enclosures and i got no hum in any of them!
May we see your circuit for your power supply?
Canis guitarus
I will have to draw it up lol but essentially its 2 of the GG ones built on perf board with a single transformer and bridge rectifier supplying the DC to the voltage regulators.
Earthscum
I have a PS that I built (R.G.'s design, if I remember right) that has some big filtering on it, and I use an AC wall wart. I get massive noise from it from your typical ground loops. I have the plastic box with a metal top. When I get hum, I can touch the box and my bass and it goes away. If I plug it into a different outlet than the amp, it doesn't have as much noise. :shrug:
Canis guitarus
SpufuZ
That one is stolen from the GGG-site.
You can see the General Guitar Gadgets-waterstamp in the background.
So yes, that one will work very well.
Canis guitarus
Absolutely lifted from their site (and many thanks to them) just with the added paralelled VR and smoothing cap.
One thing I did do, since both supply circuits were very lightly loaded, was to put the VRs back to back and bolt them to the same heatsink. Would that make a difference?
Canis guitarus
Just on a hunch I upped the value of the first filtering cap to 1000mf, plugged it in and turned it on - quiet as a wee mouse YAY!
Out of interest I separated the two VRs from the common heatsink as well - not a jot of difference.
SpufuZ
Ok sorry i didnt realize that i was you who made that schematic!  :D
Nice to hear that it works allright!
Max A on the TO220 VR´s are about 1-1.5 amps right?
I dont´t think sharing one heat sink with two VR´s will be any problem if you don´t load them with more than about 500mA each. (just my guess and not what i know)
And you can have a LOT of pedals on 500mA.
Canis guitarus
No worries lol.
My thinking exactly. The transformer I salvaged was good for 2 amps at 9V and big current VRs are quite expensive so it made sense just to split off the supply to 2 smaller VR's and them balance up the load on the 2 circuits. Its still overkill for what I am running but hey nothing gets hot and you can't sneeze at a free transformer eh?
