LofoMofo Diode 1N5817 Substitutes
Started by coelacanth, September 07, 2010, 07:08:34 PM
coelacanth
Gentlemen,
Just a simple question here. Planning to build myself a LofoMofo, the schematic says 1N5817 but the local store nearby only carries 1N5819.
Looking at the datasheet (http://www.jaycar.com.au/images_uploaded/1N581719.PDF), the only major difference I can see is the voltage, however, I'm not sure how it would affect the way the circuit works.
Has anyone here tried building the pedal using 1N5818/19, and had a good result? It seems some people had some trouble making the distortion pot work, and I'm not sure if it's due to a incorrect diode...
Thanks for your time in advance. I'm very looking forward to this build, but just want to make sure I'm set before I start.
brett
Hi
a 5819 works fine.  Alternatively, use a Ge diode.
cheers
Brett Robinson
coelacanth
Thanks, that's good to hear.
I'll let you know with a result later on. Cheers.
