What does the sufix mean?
Started by Labaris, September 14, 2010, 11:57:36 AM
Labaris
Hi,
Is there any difference between this two IC:
TLC2262
TLC2262CP
What does the sufix "CP" mean? Is there any audible difference?
I'm gonna build a SansAmp and I've read the CP is the original IC, but it's more expensive than the other one...
A long way is the sum of small steps.
Govmnt_Lacky
The C is the temperature rating of the chip. (C= 0 Degrees Celcius to 70 Degrees Celcius)
The P is the packaging type (P= 8-Pin PDIP) This is necessary!
Ronsonic
If you look up the basic IC number at Mouser they'll have pictures of the various packages in the results display. Very handy and a little more graphic than what you'll find in a datasheet.
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
jkokura
I wonder if there's a cheat sheet somewhere so I can learn what all the suffixes mean. Suffixes? Suffi? Suffex's? Octopi? Octopuses?
Jacob
Skruffyhound
jkokura
Bigmuffpi? Bigmuffpii? Bigmuffpie?
Jacob
zombiwoof
Any time you want to decipher the codes in the name of a chip, find the datasheet for it and it will show what the suffixes mean.
You can just do a net search for "xxxxxxx datasheet" (the xxx's being the chip's designation) and you will get results from several sources.  Or you can just go to a datasheet website and punch in the chip to find it.
Al
Labaris
Thanks to everyone.
I thought there might be something tricky in those codes (like mojo or something, the magic of vintage or "exact" components). That's why I didn't look at the datasheet.
newfish
Always check the datasheet - we're all ridiculously fortunate to have them at our fingertips - and they can save minutes (hours!) of frustration.
I was once building something with a BC184 in.  I followed the layout precisely, but didn't have a 184 - so subbed a 184L in there.
Which didn't work.
After many checks of "things I might have connected wrong", I checked the datasheets - and it turns out the pin-out is different for this particular suffix.
Datasheets.  They are the future...
Happiness is a warm etchant bath.
