echo base question-- developing hiss issue
Started by obs, September 17, 2010, 12:02:43 AM
obs
Hi guys,
I just built an echo base a month or two ago based on slacker's schematic (thanks so much by the way!).  Its been working fantastic, but I've recently noticed a rather noticeable increase in hiss and trebly noise in the delay repeats.  It's actually pretty drastically changing the sound out.
I read that a dying pt2399 makes lots of noise, so I checked the voltages across the chip and the voltage regulator.  Both look fine, at 4.5 and 5 volts respectively, so I think the ic should be fine.
Has anyone else run into this sort of issue before, and could give me some idea of where to start searching?
thanks
tim
anchovie
obs
Quote from: anchovie on September 17, 2010, 09:38:36 AM
Where did you buy the PT2399 from?
actually I think I bought it from diystompboxes
