Removing resist after etching
Started by sixstring396, September 18, 2010, 07:24:52 PM
sixstring396
Hey everyone, just one quick question.  What is the best way to remove the resist left after etching a circuit board?  Thanks.
Govmnt_Lacky
I use Scotch Brite and elbow grease. Works every time!  ::)
Kearns892
Acetone and an old toothbrush worked well for me.
Nail polish remover works well too (acetone active ingredient) but is not as concentrated. I've used it because more concentrated sources of acetone are not as available.
defaced
I'll second the acetone suggestion.  It's still commonly sold at hardware stores in the states.
-Mike
edvard
I use the "Goof Off" paint and glue remover stuff.
fatfoohy
I used acetone just the last time i used it, i just dropped it in and the resist disappeared, it was on photoresist boards though
having leftover parts is just proof that you made it better!!!!
blooze_man
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
nomorebetts
Ajax + water + scourer + a lil' rubbing works for me.
I like Big Muffs! and I cannot lie, you other brothers can't deny...
bean
Acetone melts it in just a few seconds. Start in the middle of the board and wipe side to side quickly to the edge. Then repeat for the other half. This minimizes the amount of staining on the backing material.
MmmPedals
I use steel wool. I find it faster than acetone.
