tiny tremoloOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Started by deadastronaut, October 01, 2010, 04:17:05 PM
Jhouse
Quotehi jace, that looks interesting, nice one, have you tried it?...at least its not a 2n2222 eh?.
I threw one together earlier. It works with two different 2N4871 that I pulled out of something. I don't remember what it was though. Anyway, the LED flashes, but I haven't tried it with a LDR yet to see how that works out.
Quote from: Jhouse on January 30, 2011, 04:31:02 PM
cool, at least it works/flashes.....without the 2n2222's...nice one..
@all heres the latest tiny trem schematic ok.
http://dl.dropbox.com/u/7464107/tiny%20trem.pdf
phector2004
Is this SPST switched?
Just disconnect the LDR?
Quote from: phector2004 on January 30, 2011, 05:23:45 PM
no switch?..just in/out... ???
@jace have you got an ldr?...
MetalUpYerEye
'Kay... I had built it before... Most of the circuits still there... I was one of the guys having major ticking problems...  :-\ Hopefully the sag will stop it for me too.
Jhouse
Quote@jace have you got an ldr?
I thought I did, but I couldn't find any in my parts bin. I'll have to go to radioshack tonight and knab one.
Quote from: Jhouse on January 30, 2011, 05:43:19 PM
wow what a time difference there is...its 10:45pm here....nothing open apart from pubs.. :icon_mrgreen:
phector2004
Quote from: deadastronaut on January 30, 2011, 05:31:02 PM
Well... "True Bypass" with a 3PDT would make one throw a wire, and the other throw a wire with a resistor to ground. Why not just disconnect the resistor to keep offboard wiring to a minimum, simplify parts, have sturdier switches (chances of it going bad being 1/(# poles)?)  ;D
Jhouse
I went and got a LDR and guess what. The circuit works just fine, no crackling and no ticking. I have it set up like your amoeba tremolo too.
How the LDR part of this circuit works is that you essentially have your in and out connected together and they both go to ground with an LDR between them and the ground. As the led part of the circuit flashes, it causes the LDR to change resistance and drop both its input and output to ground. This is what makes the tremolo style effect. Hope that clears up some confusion about this circuit.
ahhhh nice one jace...glad it worked out...no noise yay!!!!!!!!!!!!!.......
@phil.
ahhhhh..gotcha, wondered what you meant...yeah true bypass with a dpdt...yep.!..
i was wondering how to wire this up..but with a power led/on off....but with the rate led on all the time...using a 3dpt?
hmmmm...just tried the 220 in and out of breadboard,...no popping etc...so yeah it would be ok switching that...
hmmmm how to switch it?..the way i want it...with a dpdt?...nice reliable switch..
here's a diagram of it on vero for now...can someone fill in the switching/wiring?...im used to 3pdt's..and the in/outs a bit weirder than i'm used too...
ive gotta say this is working really well too....happy bunny at last...just need to box the bugger now ha ha...
Jhouse
I'm just glad I figured out a transistor to use instead of those finicky 2N2222a's. Unfortunately, uni-junctions are uncommon. Oh well. I'm going to order some uni's from smallbear and see if I can use them as a substitute.
A tremolo small enough to fit into a 1590a. :)
yeah, those uni's look pricey too...cool circuit though ...and above all it works.. :icon_wink:
the tiny trem would fit nicely in a 1590a..
guitarmaggedon made a nice one in a 1590a,   with wah filter too..external ldr as well...crammed in....great stuff.... :icon_cool:
any idea on the wiring above?..for power led, on/off but rate led on all the time.using a 3dpt..hmmmm :-\
Jhouse
Well, I'm on my crackberry so I can't draw a diagram.
I would just put a yellow led in parallel with the red led that is affected the ldr. That would be my rate led. Then I would wire up the switch like regular.
1 2 3
4 5 6
7 8 9
Put a jumper that goes from 1 to 9 and then put the input tip to lug 1. Lug 2 gets your negative side of your status led. Lug 3 is your cir
cuit's effect output. Lug 4 is your circuit's effect input. Lug 5 should go to ground. Lug 6 goes your output tip. Lug 7 and 8 need to be jumpered together.
cheers man, but i want to use a 6 pole dpdt..
Jhouse
Whoops. Apparently I can't read. Derp.
Anyway This is what you want. Keep the rate LED in parallel with the other one.
phector2004
#435
Ok, so pole 1 has "Wire from IN-->OUT" connected to center lug, Top lug connects to D1
Pole 2 has center connected to ground, top lug connected to indicator LED flat side.
Cheers
Jhouse
Oh now I get what you meant by the switch idea.
@jace, yeah, it wont need a millenium..its straight in out.. :icon_mrgreen:
@phil, cheers man, ill draw it up, . it was confusing me with the in/out.  :icon_redface:
i'm used to the 3dpts'....but this is a little weird to get my head round..thanks,
phector2004
nice one phil ..your a star!...brilliant.
i thought you would switch the 220/9v on off...?
edit:..oh yeah the rate led.. :icon_redface:
