tiny tremoloOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Started by deadastronaut, October 01, 2010, 04:17:05 PM
rugeb
#760
They are only improvements. I mentioned that the design is of Rob!.
All pages are only improvements..., but now:
- Input and output with the LDR is a circuit isolated from the rest of the circuit.
- The DEPTH control acts only in the LED.
- The connection of footswitch is totally different, now cuts the voltage and the guitar is completely isolated from the circuit.
- Reverse polarity protection.
- Cap filter.
- Resistors for LEDs.
Isn't that enough for a tiny circuit?
EDIT: ...and the DEPTH value!
rugeb
#762
My decal design ...
EDIT:
Rob, I know do you not like the decals, ha ha!
nascarbean_97
Does the newest layout allow for the choppy trem when the depth knob is turned up?
rugeb
Quote from: rugeb on March 20, 2012, 01:00:00 PM
My decal design ...
EDIT:
FINISHED!   :icon_lol:
NazzTazz
My contribution: another PCB, with on-board pots.
Pads:
G = Ground
A = Audio (input + output)
V = Vcc
D = (Led) Disable: pull to ground to force led off.
Should be used with a DPDT footswitch (at least), one circuit connecting A pad to In/Out jacks (when effect is on), the other pulling D pad to ground (when effect is off).
NazzTazz
My soldering iron actually died this morning (wth ? didn't know it could happen), so I'll route pcb for diystompboxes today.
Im not sure about pots orientation tho...
Sidenote: protecting diode (1N4001+) should be soldered directly on DC jack.
just as a reference , this was the one i built in the end..(final version) .works fine as clean trem, but not too aufait with distortion though ok...
http://www.aronnelson.com/gallery/main.php/v/chickpea/TS555TINYTREM.gif.html
Joecool85
Quote from: rugeb on June 19, 2012, 04:22:11 PM
I know it's been a while, but how did you get that looking so nice?  Is it a clear slide on decal type of thing?
Life is what you make it.
https://www.ssguitar.com
rugeb
#770
Quote from: Joecool85 on June 21, 2012, 11:15:25 AM
There are two vinyls: one is white for the the background, other is black  for the text.
EDIT:
Sticker: http://www.fuzzface.es/fuzzpedal/especiales/Tremolo-Rugeb.pdf
Schematic: http://www.fuzzface.es/fuzzpedal/especiales/tremolo-sch.jpg
Veroboard: http://www.fuzzface.es/fuzzpedal/especiales/tremolo-vero.jpg
:icon_wink:
RandomGlitch
#773
Hello! I've been reading this thread with great interest, and I've put together a version of this according to the various schematics on here.
What I've got is this:
  • LM7555 - a cmos 555 that I haven't seen referred to on this thread
  • A voltage starve pot to get minimum working voltage - set to about 5k at the moment - to be replaced with a fixed resistor
  • As I've reduced the value of the input voltage, I will probably remove or reduce the value of the LED limiting resistor(s)
  • 220uF decoupling transistor across +/-
  • I don't put the LED too close to the LDR - it clicks if you do.
My questions about it are these:
1. I see no limiting resistor on the RATE pot on any of the schematics - so the rate can go so high that the pulses can no longer be heard. The LED looks to be just on.  I'm pretty sure the duty cycle will be some way off 50% too.  Does anyone use a limiting resistor to cap the top speed of the rate control?
2. Would the (a) circuit shown here from the datasheet which keeps a 50% duty cycle be better? I'd never seen this configuration before. It uses fewer components, so why not use that?
3. I'd like to increase the volume ever so slightly. Some folks mentioned it earlier in the tread.  I was thinking of using a simple 2N3904-based buffer (from Beavis Audio) before the input. - has anyone actually added a buffer to theirs?
Lizard King
WOW.  Nice, simple circuit.  I've been working on a Tremulous variant but I think I'm going to throw this one together too.  I love tremolo!
gcme93
Tiny trem time!
Awesome design, can I get a second pair of eyes to check this over before I build it? I'm aiming for 1590A! First tiny build
Thanks,
George
Piss poor playing is why i make pedals.
gcme93
eurgh completely forgot to bias the input and add decoupling :( feel like a bit of an idiot, ignore the unbiased nature of the schem, I'll add that in off board.
Jasonmatthew911
I finally ended up breadboarding the Tiny Trem circuit and it seems to be working as intended, as long as I use it by itself or in front of other pedals as the first effect in the signal chain...As soon as I connect an overdrive or fuzz before the tiny trem, it seems like the Tiny Trem circuit gets completely ignored, like it gets bypassed or something, cuz you won't even hear the clicking sound in the background...To me it seems like when my distorted signal gets to the input of the LDR it just goes right through the output unaffected by the LDR/LED/555 circuit, since the input and output are connected to the same leg of the LDR on my breadboard...I have no dpdt switch connected at the moment...I'm doing all testing by connecting my overdrive pedals directly into the Breadboarded Tiny Trem circuit...This behavior makes no sense to me, as I've seen this type of effect connected after most pedals and the stuttering is very noticeable on any effect before this, as it should be chop all other effects on and off that are before it....A Tremolo effect should work best around the end of the signal chain, but right now for me it's only working as the first effect in the signal chain.....Does anyone have an idea why this is happening or what my issue is?
Jdansti
Quote from: Jasonmatthew911 on April 10, 2013, 11:52:57 PM
http://www.diystompboxes.com/smfforum/index.php?topic=102137.msg905933#msg905933
Jasonmatthew911
Quote from: rugeb on March 19, 2012, 12:28:29 PM
Schematic VERIFIED, and it sounds cool!
I did Rob's version of the Tiny Trem, and now I did this version...They both work well on their own or as the first effect in your signal chain, but as soon as I turn a distortion or other effect ON connected in front of the Tiny Trem, the Tiny Trem gets completely bypassed and doesn't chop the signal....Has anyone else here realized that the TT is a great little circuit, but it seems like it can't be used at the end of your pedal chain with other effects ON in front of it, which is where you would normally want a Tremolo effect?...I'd like to be able to get a strong choppy killswitch stutter with a distortion in front of the TT, but the TT just gets bypassed...If I connect the TT first in the chain, then the effect is somewhat noticeable with other pedals after it, but the chopping on and off effect isn't very intense...Anyone know of a simple way to fix this issue?
