best capicitor for a flatline?
Started by fatfoohy, October 06, 2010, 09:47:34 PM
fatfoohy
So, question time.  The capacitor parallel to the LED from the led/ldr combo, what is the best value for it? i was thinking that maybe if you made it a smaller value, it would cause a quicker attack time. However i have no idea, has anybody played with this thought? I'd do it myself, but im putting it in a 1590A and the cap with a socket doesnt fit. Thanks in advance
having leftover parts is just proof that you made it better!!!!
CynicalMan
The attack time is mostly set by the LED/LDR. Reducing the cap reduces attack by a little bit, but not much, and reducing it too much causes a growly distortion on decays when the compression is turned up. I used 47u in mine because that was the lowest I could go without the distortion.
fatfoohy
hmmm alright thank you for the insight, im just gonna go with 1 uf and hope for the best
MartyMart
I used a very small 16v 100uf cap .... no problems in a 9v circuit.
MM
fatfoohy
hmmm.....boxed it up, but there's some distortion, i think i may have a short somewhere, but could the capacitor be causing this? it's just a little distorted
CynicalMan
Try increasing the cap from 1uf to 47uf or 100uf. Like I said, I got distortion when the cap was lower than 47uf.
Slade
1uF is way too low for that cap. I use 100uF too. I'm gonna try a 47uF, though, CynicalMan :icon_smile:
fatfoohy
hmmm, well i have a 1uf, 4.7uf, 10uf, 47 uf, and 100uf, so maybe i'll check out the 47 and 100 tomorrow, thanks for all of your help guys!
askwho69
IS FLatline Comp quieter than CS-3? is this required for boosting distortion? thnaks
"To live is to die"
MartyMart
fatfoohy - Just checked mine and it has a 16v 47uf in that position, I remember having a bit of
distortion and "weirdness" when going lower than that.
askwho69 - Flatline is very quiet in operation and has a TON of output volume for some great boost also.
MM
fatfoohy
hmmm, yeah well i'll definitely try out a 47 and 100, for the record.....i feel retarded for misspelling capacitor in the title of this post
fatfoohy
wow......put in the 100uf, fired this thing up, sounds amazing! i added a switch to go between normal, a boss, and then the expansion mod, and it sounds amazing all around! it really makes my slap bass sound orgasmic(am i allowed to say that?) thanks for your help guys!
fatfoohy
got it boxed and working! my second build ever, and first in a 1590a, I'll post pics monday, it's late, and tomorrow im out of town
askwho69
WOW really! i want this :))) can someone share some PCB on this great compressor please really need a compressor as booster CS3 is very noisy its great but low output :(
"To live is to die"
fatfoohy
sustain is a 100k linear pot, volume is a 100k logarithmic, the switch and be a two or three way, two way(on on) would be compression and expansion, 3 way (center off) would be compression boost and expansion. to omit the switch put a jumper between where the wire connects to the board for the switch's middle lug and the pad that connects to the IC's first pin(between the red and black wire's pads
askwho69
Thanks A Lot  bro.. is this layout verified? :)
"To live is to die"
fatfoohy
it was verified before i added the mods for a switch, and now i have verified it (i omitted D5 for what it's worth)
Hides-His-Eyes
Protection diode backwards? Or have I missed something in the reflection?
Looks to be shorting 9v to ground...?
fatfoohy
oh no idea, i didnt make this layout....
askwho69
i found a thread a while ago and it was said that d5 is backwards.. we can omit it as you did  :icon_question:
"To live is to die"
