COMINBING 2 PCBS IN ANY PEDAL OTHER THAN A TRUE BYPASS PEDAL...
Started by dmc777, October 10, 2010, 02:15:42 AM
dmc777
Could someone please explain to me how to add this in a schematic? Examples are Barber Comp, DMB's new line of pedals, and the dyna"RED" Ross comp vero in the gallery.
I'd like to learn to apply this to ANY or most situations. I know you guys know. Speal the beans!!! :icon_mrgreen:
GibsonGM
I think you might need to be a little more clear on the 'logic flow' here, DMC.
What exactly do you mean - like, PCB > PCB >output?  Or, both PCBs in parallel?
And, adding something 'in a schematic' is not the same as adding something to the real world...no offense meant, just need more info to help...
dmc777
I really interested about both.
1. Adding a blend function in an already built pedal or unbuilt pedal.
2. How to basically add 2 stompboxes in one housing but be able to run them off 1 9v jack as well as be able to use each effect seperatly or together. Something like Cmatmods Super Signa Drive. Basically a boost and an od.
anchovie
Quote from: dmc777 on October 12, 2010, 11:34:45 AM
Connect both circuits to the same 9v jack.
Connect the output of the first FX footswitch to the input of the second FX footswitch.
Easy really - just imagine how the power and signal would flow if you had two pedals with a 9V daisy chain and a 1/4" patch lead.
Skruffyhound
I'm not quite sure what the question is I didn't bother to read properly, but this will change the order of your effects AB - BA,
the rest of that thread is also a good read.
http://www.diystompboxes.com/smfforum/index.php?topic=84690.0
There! I totally didn't answer your question, but this is something else that you might find amusing.
Skruffyhound
If you have any other questions I'd be happy to not really address some other issues for you.
dmc777
