Adding zeners in series
Started by Mark Hammer, October 25, 2010, 10:35:29 PM
I need a 5.6V zener.  None of the local electronics places either have them in stock or are open when I can get to them.  Can I simply stick two zeners in series that add up to 5.6V (or close enough)? the same way adding regular silicon switching diodes are added to achieve different forward voltages?
Yes. There are the usual string of caveats, but yeah, the voltages add.
At one time NPN transistors had a reverse base-emitter breakdown centered between 5 an 6 volts, but I notice that this has drifted upwards in recent years, so you may not get lucky and get one that you like.
The temperature drift of a zenered base-emitter and a forward biased base-collector tend to cancel, so if one needs a 6.x to 7.x volt low-tempco voltage, using an ordinary NPN with positive on emitter, negative on collector, base open, tended to produce that. I haven't tried this for a couple of decades, but it used to work.
Adding forward biased diodes to zeners works too, but the current/voltage knee gets sloppy compared to a nice, sharp avalanche device.
