Epoxy Removal
Started by { antonio }, November 04, 2010, 02:57:26 AM
{ antonio }
What are you doing to remove expoxy from at circuit board?
I have a Maestro Sustainer that needs some rewiring but the wire are in a pile of goop!
Any help would be great!  Thanks!
shalom + godspeed.  antonio.
www.myspace.com/magnificat
Jaicen_solo
Acetone will do the job but it will probably ruin the shielding on the wires.
{ antonio }
You know, I used a heat gun and it did the trick.
I just need to chisel enough epoxy to solder a new wire together.  Thanks for the heads up on acetone!
wavley
I used acetone to remove the goop from pesky Juno 106 DCO chips to repair them, it worked quite well.
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
