Metal Film Capacitor Question?
Started by soupbone, November 09, 2010, 02:55:45 AM
soupbone
Can you use metal film caps that are not polarized,but are the same value to replace electrolytic caps that are?
MartyMart
Yes if they are signal bypass caps, such as from a fet or BJT to ground or blocking caps at the input to a circuit etc.
No if they are power supply caps from V+ to ground or 1/2 V to ground ( unless you want to add a parallel 0,1uf non polarized cap along with an electro cap )
MM.
soupbone
Ronsonic
Quote from: soupbone on November 09, 2010, 02:55:45 AM
If you've got room for them.
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
