On-board LPB1?
Started by JEPorter, November 14, 2010, 07:38:29 PM
JEPorter
I'm thinking of doing some mods to my Strat and plan on using an onboard preamp...The Stratoblaster was recommended and I have the parts on the way...but I was wondering how an LPB1 might compare as far as potential volume output...does anyone know how many decibels of gain an LPB1 might be maxed out?
Thanks all,
Jeff
Jeffrey
JEPorter
I know there would be variables depending on the components...but I'm just wondering about general figures...
J
Jeffrey
blooze_man
I don't really know the numbers, but I built one and it gives a good amount of boost. If you place it before an overdrive it ventures into fuzz territory. Which is cool.
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
  My druthers were about what they sound like since I toned them down for in-guitar use.
  And used DPDT/100k pot assigned to pull/on, push/bypass, so the bypass and amplifier circuit aren't too far apart from one another in output, I liked the enourmous output of any booster [ie most of them are far above unity when turned down to even 80% or so of their output], but the 'blast of overboost', especially for clean sounds /or/ more useful bypass being say 10% above unity or so made pulling the effect on while playing a less shocking experience, having to pull/readjust volume/start playing again was required to avoid speaker-blasting when switching on the onboard preamp.
  Another player might always keep the booster driving a next circuit which distorts/compresses, so having huge increase from raw pickup volume or even not having raw pickup available [PU>hardwired booster/no bypass] might be more suitable for these intended purposes.
  A dist+ for instance puts a hard-ceiling on volume, any voltage above X doesn't get past this circuit. Boost increases = more clippings-shunted-to-ground.
  A non distorting amp hit with boost may produce enourmous volume changes, the speaker and ears found them to be irritating or dangerous.
  Since I use pedalboard, and stout/not too long guitar>cable to it, I tried 20 boosters, and have an often chosen OScomp as 'booster'.
  For in-guitar I chose a reduced gain stratoblaster, volume control at the end also works PU, when stratoblaster bypassed. I guess it'd be called 10 or 20% 'boost.
Hides-His-Eyes
I would personally not recommend the LPB-1 for this purpose because it does not have a very high input impedance at all (not even 50kOhms) and so might result in a loss of treble, although this is less of an issue when there's no cable to deal with.
Have a look for the "crackle not OK" circuit; that might sound better to you.
