What to do with unused pins on CD4049 or CD40106???
Started by richon, November 20, 2010, 07:26:46 AM
richon
connect them to ground or +V??
should the input be to some of them connected and the output not connected (when not used?)
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
Yes you just connect the unused inputs to ground or +V, it does not matter which. You can just leave the outputs unconnected.
edvard
Or you can put them to good use.
Use a few of the other stages to make a "second channel" a la the DoubleD:
http://www.runoffgroove.com/doubled.html
If you're into solid-state switching, you can use two of the inverters in a DOD-style flip-flop:
http://hammer.ampage.org/files/dodswitch.gif
Dang, that's all my ideas.
HTH...
