Maximum supply voltage for op amps
Started by El Heisenberg, November 26, 2010, 01:25:45 PM
El Heisenberg
When a datasheet says the max supply voltage for say a TL082 is +18v:
http://www.st.com/stonline/books/pdf/docs/2300.pdf
Does that mean you can power the op amp with +18v and -18v using 0v for the vref?? Or is it only just 18v and the usual 4.5v goes up to 9?
"Your meth is good, Jesse. As good as mine."
Gurner
The pertinent info is in the plus & minus symbols in front  (table 1 in your datasheet you've linked to) ...±18V - therefore it'll handle 36V max supply.
Mike Burgundy
Possibly quite unneccesary to point out, but just in case: remember that Vref is "ground" as far as the opamp is concerned (as in: most opamps want a bipolar supply, and we usually fool them into buying a +/-4.5V supply with Vref at half supply or battery voltage, acting as ground level for the opamp....)
El Heisenberg
