6832 submini
Started by demym, November 27, 2010, 05:24:31 AM
demym
Hi,
i have found these on ebay, 6832 mini tube (dual triode).
These are the specs:
Quick Specs:
Heater Voltage - 6.3v
Heater Current - 400ma
Typical Plate Voltage - 100vdc
Typical Plate Current - .8 ma per section
Amplification Factor - 26
Transconductance - 1050
Do you think they could be more or less equivalent to 6111 ?
Thanx in advance, bye
maarten
Seems close enough to me, should work. Maybe you will need a somewhat larger cathode resistor to get the right negative grid bias, you can find that out by experimenting with a potmeter (e.g.5K.
Maarten
demym
