Rotary Switch
Started by modmuffpi, December 02, 2010, 02:15:15 AM
modmuffpi
I'm trying to find a sp4t rotary switch for a pedal i'm trying to mod. Preferably non-shorting. And i'd rather not spend $10 or more per switch if possible. Is this a very rare switch to be had? I get very limited results when serching google. Can anyone refer my to any sites with a selecton of these. Even sp5t or sp6t will do.
slotbot
you will probably have an easier time findind 3p4t, which will work for you as well.
not associated with this auction but here for example is 6 for 11 bucks that came up when searching "3p4t" on ebay.
http://cgi.ebay.com/6-Rotary-Switch-3-Pole-4-Position-3P4T-Non-Shorting-4P-/300348030269?pt=LH_DefaultDomain_0&hash=item45ee233d3d#ht_1804wt_905
just use 1 of the poles and you have what you want. (times 6!)
edit: this "style" is around a lot and usually available as 4p3t, 3p4t, 2p6y 1p12t etc.
smallbearelec
alparent
Futurlec as them for 1$. I get them all the time. 3P4T.....just use one pole.
The rotaries i usually see have an adjustable stop so anything you buy could be set up as a SP4T, a SP12T, 2P6T, 3P4T or other combinations are all going to be viable options.
modmuffpi
Quote from: smallbearelec on December 02, 2010, 07:41:29 AM
Please check out the rotary switches in my Stock List, as there are a few that would work:
http://www.smallbearelec.com/Categories.bok?category=Switches%2C+Relays&searchpath=2033069&start=49&total=63
SD
Awesome site. It has everything I'm looking for. Are there any promo codes that I can use?
Thanks everyone for the help.
