'LIGHTWAH'
Started by deadastronaut, December 08, 2010, 11:08:59 AM
threepwood
Ha ha.
Arghh.. 2 last questions (hopefully) :icon_redface:
On the top right of the layout pdf there is something marked sw1 sw2 sw3
Am I right in guessing that this is the left 3 lugs of the footswitch?
Should all LEDs have resistors attached?
Thanks again!
SW1/2/3   is for a toggle switch...so you switch between footwah, lfo wah...its an  spdt switch.
all resistors are on pcb....apart from your footswitch one which is off board ok...
heres a pic..
threepwood
Fantastic. Thank you sir.
nexekho
Am I right in thinking that the LDR on the op amp feedback could be replaced by just about anything such as a transistor or potentiometer to sweep the wah?  Love the sound of this thing.
I made the transistor angry.
the wah can be swept/fixed with the sensor pot anyway......dark and light!....back n forth!..
expression pedal?.. :icon_idea: is that what your thinking..
nexekho
I was thinking about mapping input amplitude to wah sweep so it works like an auto wah.
hmmmm interesting...sounds like a good option/addition... :icon_cool:
threepwood
I'm just putting a parts list together and was wondering what size enclosures you guys are using?
1590b....hammond/eddystone... :)
bigmufffuzzwizz
I got turned on to your project just about a week ago, man I love it! Your video demo are really awesome! Putting this on my to-do list, hopefully sooner than later..Did any LDR work fine for the external sensor? I usually use the only one that Tayda sells..
Magic Pedals Home of The Shrine Fuzz!
cool:  i used a 5k-1M ldr...  ;)
add4
I can attest that with a 10r - 22k LDR, the external sensor does not work when placed into a led bezel under a clear led :)
Waiting for my tayda order too .. it's been sent 10 days ago .. i check the mailbox everyday with a thrill ..... and don't find anything .. i have 4 projects depending of this shipping :)
Quote from: bigmufffuzzwizz on November 28, 2011, 11:36:34 AM
ahhhhh patience!!!!... :icon_cool:
threepwood
Has anyone got a photo of how they have mounted the LDR inside the LED bezel?
i haven't,  this is what i did..
i took a clear lens led cut off the legs and sanded/filed the bottom flat then using the ridge of the led i glued it into a bezel...
then i put heat shrink on th legs of the ldr and put a blob of superglue on the top face of the ldr and pushed it into the bezel...then put your
bezel gromet on the legs of the ldr....sorted!... ;)
threepwood
Hmm... I think I see what you mean. It's a little hard to visualise without the parts in front of me. I'm sure I'll bodge something together!
Thanks.
add4
why the heat shrink on the legs of ldr?
Quote from: deadastronaut on November 29, 2011, 08:38:07 AM
just to stop them little spindly legs touching the inside of the metal bezel  :)
add4
I just built it using this schematic and deadastronaut's layout ..
it works great ... but i got ticking each time the LFO led turns on and off..
i have reread the thread about the ticking thing and it seems there is no mention of that for a long time ..
Does anyone have an idea on what i could try to get rid of this? first time i mess with LFO's and i don't have any idea what could cause that.. i guess it's around the LFO IC, but that's all :)
thanks in advance.. can't wait to put this in a box!!!!! !! !! !! !! !! !!!
