74C373 Octal Latch problem
Started by served, December 18, 2010, 05:38:12 AM
served
Hi.
I am having some problems with 74C373 Octal Latch.
If I power it up. All the outputs are "On". If I feed one D with signal (+5V) then Q will rise and the others fall. But If I stop feeding D everything falls.
What am I doing wrong? Why are Q-s on if I power it up? Why Q falls to 0 if I stop giving input.
I would like Qx to stay high, if I momentarily give signal to Dx.
If I give signal to Dx+n then Qx should go low and Qx+n should go high.
And I dont like the start up thing.
I hope its not too comlicated, but I don't know how to explain.
Octal latch is MM74C373N
A.
served
OK. I got it working. I needed that pulldown resistor for LE.
But still. Why are all Qs High, If I power it up?
A.
http://www.geofex.com/Article_Folders/VCA%20Applications.pdf   - page 5.
Don Lancaster's TTL Cookbook, also CMOS Cookbook.
Generally: all unused pins MUST be forced high or low, the start-up state of a flip-flop is NOT defined (unless it has a Reset pin and you use it tight).
