Holes for pcb
Started by soupbone, December 22, 2010, 02:29:31 AM
soupbone
I'm getting ready to etch my first pcb board! :icon_biggrin:What size of drill bit should you use to drill the holes for the resistors,capacitors, etc.?
Cardboard Tube Samurai
Zapp Brannigan
#3
I use 0.6-1 mm drills, depending on certain component's leads diameter. 0.8 mm suits fine in most cases.
bassmannate
Are metric bits readily found in the US? All I've ever found is standard sized ones.
dedguy
You can find metric bits in the States, but you have to order them, I use carbide metric ones all the time at work. If you get a 1/32 drill bit it measures out to .79mm, and that you can find at your local hardware store. Good hunting. :icon_mrgreen:
soupbone
Hmmm..Thanks for the answers!So,I'm guessing from everyones answers between a .79mm or an 8.0 is the best?
newfish
I've had very passable results with a 1mm bit.
The hole size is perfect for off-board wires and component leads alike.
Happiness is a warm etchant bath.
Quote from: newfish on December 22, 2010, 11:17:48 AM
till it comes to the ic pads...and it rips em off the board.... :icon_mrgreen:
soupbone
Quote from: soupbone on December 22, 2010, 11:12:37 AM
deadastronaut said 7.0.I'm confused. ???
dedguy
Reread his post it said 0.7 not 7
ACS
#11
Quote from: bassmannate on December 22, 2010, 08:56:20 AM
I genuinely laughed out loud at that one... (no offence bassmannate ;))  "standard" when referring to a system that in the whole world only the US and some sectors in the UK still use, just made my day...
soupbone
dedguy
Two of the places to get bits from is MSC Industrial Supply and McMaster-Carr. I don't know about shipping and stuff like that, but I do know they have all the sizes that you could ever use !!!!
peps1
1mm perfect for all old and new components (some old old parts like mustard caps have issues with smaller bits)
smallbearelec
You should have twist drills in the range of #59 to #63 to accommodate a variety of lead diameters.
WE HAVE DRILLS..and Dremel accessories, and lots of other tools, as well as storage for such!
http://www.smallbearelec.com/Categories.bok?category=Tools+-+Drills
Note that assortments are available, and I have both the regular "jobber" drills that fit a Dremel collet and the 3/32" shank types to fit a Jacobs chuck.
Most people know me for parts, but I have also done my best to have all of the "other stuff" that otherwise has to be mail-ordered. Please do check out those sections of the store and give yourself a CHristmas/New Year's present!
For those who need an overview of what tools to buy for pedal-building, here's a shopping guide:
http://www.smallbearelec.com/HowTos/Tools/Tools.htm
Regards
SD
blooze_man
I use the #60 from Smallbear. Wires fit perfectly without the holes being "too big" for component leads. Can't remember what guage wire I use.
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
darron
Metric IS standard size......
sigh....
I use 1mm but my donuts are usually a bit bigger than most PNP transfers provide
I've found a #72 and #66 (or 65) cover just about everything in a pedal build, however they're both pretty fragile. [With numbered bit sizing the larger the number the smaller the bit, #72 (.0250) & #66 (.0330)].
http://drillcity.stores.yahoo.net/newtuncardri.html
dave
teemuk
I don't use just one bit size, because neither are the component leads always the same diameter.
0.7 mm is a good standard choice that fits most component leads of low-power resistors, caps, semiconductors etc. If the hole is for bulkier wiring, or power resistors and alike, I switch to using a 1 mm bit. Holes for trimmers and potentiometers usually require as big as 1.5 mm  bit because of the rectangular shaping of their leads.
