Bypassing millenium bypass
Started by Axe_34, January 10, 2011, 07:59:58 PM
Axe_34
Hi everyone.
I've got a Tonepad AMZ Mosfet boost PCB but I don't want to use the mill bypass and want to use a 3pdt switch instead.
Looking at this layout, I'm assuming I just have to leave the mill components off the board and wire the in, out, 9v and ground as you would usually hook up a 3pdt switch for true bypass.
http://www.tonepad.com/getFile.asp?id=87
Thanks in advance for your help.
pazuzu
