Looking for good LFO circuit for adding to effects like crash sync and PWM
Started by amnesiac, January 10, 2011, 10:06:20 PM
amnesiac
I am trying to find a good lfo circuit that I can add to effects.  Ideally with some different waveforms.  THanks.
brett
Hi
You can use sections of a 4049 to oscillate square wave, integrate to a triangle, and then clip to a pseudo-sine wave.
search for it, either here or on the web - it so simple it seems impossible
cheers
Brett Robinson
CynicalMan
If you want loads of controls, check out the tremulus lune LFO. Otherwise, +1 to brett's suggestion.
Hides-His-Eyes
http://electro-music.com/forum/phpbb-files/4049trisin_442_182.jpg
How does that look? I love the idea that using a 4049 instead of a dual op-amp could give you a pseudo-sine LFO rather than a triangle.
thomasthebuzzard
Does that require you to bias it on or will it work with typical 9v?
Hides-His-Eyes
I got it from a synth website; they tend to use bipolar supplies. I would connect to Vref with a 1M resistor.
If someone with a scope would try it out and find out what the p-p value is of the sine wave I'd appreciate it.
daverdave
I've said it before and I'll say it again, opamp schmitt trigger / integrator oscillators are my favourite. You can get nice square and triangle waveforms out of them, plus you can easily mod them for symmetry.
