dynacomp (tonepad) loud popping
Started by Bullet79, January 19, 2011, 01:04:13 PM
Bullet79
it has 4.7m at the input.... what can i do more?
JDoyle
Read and follow the instructions in "DEBUGGING - What to do when it doesn't work"
You gave far too little information for anyone to ever be able to help you.
Regards,
Jay Doyle
Bullet79
it already had 4m7 pulldown resistor.. but still pops.. where to put the 'fx out' pulldown resistor..?
JDoyle
See - I thought your first post meant that you had 4.7mV on the input. "m" means milli-, not mega, which is "M"
You don't need a pull down on the output, the level pot already serves to do the same thing.
No one will be able to help you without more information.
Govmnt_Lacky
Quote from: JDoyle on January 19, 2011, 02:45:57 PM
Regards,
Jay Doyle
+1. Definitely read the DEBUG thread and repost with more information. It will get you answers faster.  ;D
johnravacio
@Bullet79: Any news at this? I'm having the same problem as this (loud popping when you turn on the switch).  I built the dyna/ross comp with RoDYMod from tonepad. Thanks!
bluesdevil
Let's pile up... I also had a loud pop when engaging footswitch with my build last year, but just dismissed it as amplifying mechanical noise of the 3pDT.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
Xavier
One more to pile up..............built using GEOFEX's schematic below
Anybody experienced the same issue ?. I see no output cap, could it be the case ? LED popping ?
Steve Mavronis
Try wiring it to a 3PDT this way. The PCB input will be grounded when you switch. It eliminated having pops in my builds of a custom 250 Overdrive and Dyna Comp:
http://gaussmarkov.net/wordpress/thoughts/wiring-up-a-1590b/
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
Xavier
Thanks for the suggestion Steve, today I'll try , along with Aaron's LED popping mod. I hope this solves the issue.
