DOD FX25B - Force to power up in off.
Started by bassplayer, January 27, 2011, 10:42:01 AM
bassplayer
When the FX25B powers up it's on.
Is there a mod to force the CD4007 to power up in off mode instead?
runmikeyrun
all i can think of is a switch connecting the battery ground to circuit ground on the input jack, because how the pedal turns on- when you plug a guitar into it the two terminals connect on the sleeve of the plug.  If you had a switch you could flip it on and it would make the connection for you, which would turn the pedal on.  I don't know if there's really a way to turn on just the chip, unless maybe you wired that switch to the chip's ground.  But why would you want to only turn on the chip?
Bassist for Foul Spirits
Head tinkerer at Torch Effects
Instagram: @torcheffects
Likes: old motorcycles, old music
Dislikes: old women
bassplayer
Quote from: runmikeyrun on January 27, 2011, 06:07:31 PM
I mean:
"on" = effect in
"off" = bypass
The pedals power up default is "effect in". I simply wanna modify it to "bypass".
twabelljr
My Boss pedals do that. When the board is powered up all of the Boss pedals turn on automatically and I have to turn them off. My Tubescreamer uses jfet switching also and it is off until I turn it on. Making the pedal true bypass would solve the problem, if you want to add switches and drill holes in your pedal. This article explains the Boss and Ibanez jfet switching. Maybe someone will know why one powers up engaged and the other powers up bypassed. I don't. http://www.geofex.com/Article_Folders/bosstech.pdf. I am curious if there is a mod for this. I have not searched, I just understand your complaint. Not sure how DOD switching works.
Shine On !!!
SISKO
--Is there any body out there??--
bassplayer
Quote from: twabelljr on January 27, 2011, 08:01:28 PM
There are info out there how to change the default state for the Boss flipflop circuit. It's a matter of changing the balance between "flip" och "flop". For instance I have a bassmodded BD-2. In that case I was rude with a soldering iron to one resistor. It was enough to change the balance.
This is another great article:
http://www.bossarea.com/forum/topic.asp?TOPIC_ID=1036
Quote from: SISKO on January 27, 2011, 08:26:47 PM
Read this, it will probaly be of some help
http://www.thetonegod.com/tech/state/state.html
Thanks mate, I'll look into it.
