Building the Tiny Giant amp
Started by Taylor, February 02, 2011, 11:47:46 PM
Taylor
Hmm, if I understand you correctly, the "grommets" are just the regular holes that the parts go in like any other PCB. If you're used to single-sided boards etched at home, the difference between that and these is that these are "plated through holes". The pad that you would solder to on a single-sided, home-etched board is still there, but the inside of the hole has metal plated into it to make a better connection, and so that you can solder from either side of the board, and to connect the top and bottom copper layers.
But you can solder to it just like any other kind of pcb. No special tool is required. You don't need to get the iron inside the hole, just heat the pad and component lead as you normally would with any PCB.
You'll be fine with an 18v supply. I'm using a 19.5v one and a box smaller than a standard RACO.
Your ground connection for pedals should probably be the ground tab on your power inlet jack.
David
Quote from: Taylor on February 14, 2011, 11:26:46 PM
Excellent to all the above.  Exactly the answers I was hoping for.
StarGeezers
 Taylor , got my Kit !!  What a Beauty , and TINY ... :icon_eek:  Very COOL !!!   :icon_cool:  This just looked like too much FUN to pass up !!!  Thanks ,  Dude !!!
Brymus    Possibly :icon_surprised: ... Doing Good , got a CD ... Surprisingly  very Close to Taylor  ... Yes , still Croaking ...   :icon_mrgreen:
culturejam
Got mine today as well. Can't wait to get it going. :)
thedefog
I'm noticing on mine that there is some very low level distortion going on, even with the guitar volume rolled down and volume on the amp low. Where could something like that come from if it isn't dependent on the input volume?
Taylor
The distortion really is the same regardless of input volume, or it's there at any input volume (but more distorted at louder in volume)?
David
Taylor, I still have to connect the "offboard" components on mine.
What I need to know is, how much current can the "offboard connection" really supply?  Can it go to an amp?
If not, I can always use a 9V wall wart like I do now. I had thought about feeding the "offboard connection"
through a LM317 set up to deliver 9V.
It would sure be nice to just have one power cable coming to my pedalboard.
Taylor
The onboard voltage regulator has a max current capability of around 5 amps as I recall, but check the datasheet. Assuming your power supply puts out that or more, the current available for pedals would be that minus the actual current draw of the amp. I haven't had a chance to measure current draw yet, but I wouldn't be surprised if it was something like 3a or less in regular use.
David
Quote from: Taylor on February 17, 2011, 02:29:03 PM
So that pin that is marked for offboard connections in the build document does not connect to the half of the TL072 that is creating the bias voltage, then.  OK, got it.  EXCELLENT!!!!!!!!!!!!!  THANK YOU!!!!!!!!!!   :icon_mrgreen:
Kain
Just ordered Tiny Giant amp + Christine, can't wait. Thank you.
Kain / Vasuri Kabala
Octavia/D-Reverb/Ampeg Scrambler/2*TS-808/Fuzz Face 69/Ross Compressor/Oscillator/May Queen/Drawdio/Professor Tweed/Supreaux/2*Ruby/ZVEX Fuzz Factory/Valve Caster
thedefog
Quote from: Taylor on February 16, 2011, 01:54:35 PM
It's there regardless of input volume. Not more or less at different levels (unless it's cranked and it's breaking up obviously).
Taylor
Hmm, that's quite strange. Generally, distortion means clipping. But I can't think of any normal way that something could clip where the amount of distortion does not vary with input volume.
Are you plugging your instrument straight into the TG? Is it a guitar or something else? If a guitar, is it a normal passive one?
defaced
Got mine built.  A couple of naked box shots and the power adapter I'm using, $9.80 on eBay.  I really dig this project.  And it plays just fine with a 16 ohm cab.
Fiber isolation washer to keep the output jack, well, isolated from the chassis which is at ground potential.
$9.80 on ebay. VAIO Laptop 19.5V 4.7A from seller laptopz-outlet.
http://cgi.ebay.com/AC-Power-Adapter-Charger-fr-Sony-VAIO-Laptop-19-5V-4-7A-/310229426156
-Mike
waltk
QuoteGot mine built.
It's beautiful.  Nice work!
doug deeper
Ordered mine!
Gonna try it for monitoring with my mono reel to reel recording rig.
David
I'm working on testing mine now, which is proving interesting since my guitars are in the shop and I'm
trying to improvise using a signal generator.  I had issues with the op-amp not being in all the way and
a faulty mute switch.  I tracked these down and I'm going to put a different switch in.
What I'm noticing is that the 10K is not acting quite as I expected.  It was marked 10K audio, so I don't
THINK it's linear, but it's not acting like it's logarithmic.  I get nothing for probably a third of the pot's travel,
then the volume climbs like a Saturn V taking off.
Any ideas?
Hides-His-Eyes
I think I'm going to build this in a box with one of those FET Fender blackface Preamps all in one box.
Not really a related question but say I wanted to use a MAX1044 to run that at 36V; the max the 1044 can take is 9V, right? Would I want to use a regulator for that, or just run a voltage divider into an op-amp buffer at the full voltage?
defaced
I don't think you can. http://pdfserv.maxim-ic.com/en/ds/ICL7660-MAX1044.pdf
From the data sheet:
QuoteAbsolute Maximum Ratings
Supply Voltage (V+ to GND, or GND to VOUT)....................10.5V
It looks like you're limited to 10.5v, or we'll call it 10v input, and if I'm reading that right, 10v max output.  It looks like they stack the Vout on top of Vin to get voltage doubling.  I'd verify this information, I've not read the entire data sheet or really worked with this device.
-Mike
Hides-His-Eyes
There's a way to get 36V using diodes; it's on geofex.
Skruffyhound
You can get there with a charge pump, but I don't know what's happening on the current side of things.
