where to order wall warts ??
Started by buildafriend, February 13, 2011, 04:34:10 PM
buildafriend
i live in new jersey on the east coast of the U.S.
i need 2 wall warts but i don't know where to order.
Input:
120 VAC
60 Hz
23W
Output:
16 VAC
1000mA
Also need
input 120VAC
60Hz
Output 12VAC,
anywhere from 500mA to 1000mA will work.
CynicalMan
Check your local thrift store. Seriously, a lot of them will just have a bin of miscellaneous wall warts for $0.25-$1 each.
KazooMan
No thoughts on where to order, but I would ask what you are going to use them for.  The output from typical wall warts is usually not the best and it can create problems (hum, hiss, white noise, etc) down the line.  OK for charging batteries, but not ideal for music.
If the pedals you are going to use these with have good filtering built in, then go for the thrift store variety.  If you want something that puts out a clean, consistent voltage, then you should consider building your own.  There are many kits and/or schematics available.  You can easily build a power supply with multiple outlets to run several pedals.
defaced
These aren't wall warts in the way we typically think of them, they're AC, so hum, hiss, etc won't be any different than the original unit because all of the power filter circuitry is inside the device that's using these.
I'd try eBay for these.  Just pop in the secondary side information and see what comes out.
-Mike
smallbearelec
I guess some people don't know I stock these. Not a huge selection, but best list I could put together of "most commonly used":
http://www.smallbearelec.com/Categories.bok?category=Transformers+and+Inductors
Unfortunately, the 12 VAC model that I have is a little pricey because it's an OEM replacement that I don't import directly.
Try Mouser.com...they have an enormous selection, and they are pretty easy to deal as long as you have a part number.
Regards
SD
buildafriend
Quote from: CynicalMan on February 13, 2011, 05:24:59 PM
they had one that was 12V 400mA!! rr so close.
buildafriend
Quote from: defaced on February 13, 2011, 07:16:45 PM
tried it! no luck :(
buildafriend
It's actually for this.. its a little off topic but i need a PSU for it.
http://www.musicfromouterspace.com/mfosweb/navigate.action
emstin1
defaced
If that's the chassis, screw a wall wart, put an IEC socket in it, power it from the mains, and mount the transformers inside the chassis.  If you have problems with them coupling to the circuits, put a metal cage around them that is grounded to the chassis.
-Mike
DougH
Paul Marossy
That's where I got most of the ones that I use, including 12VDC types. With the LM317 adjustable voltage regular built into my pedal boards and set at 9.5V, I can use whatever wall wart I want with it and not have to worry about it. I just change the plug as necessary.  Happy camper here.  :icon_razz:
electrosonic
I have bought cheap thrift store wall warts that overvoltaged quite a bit when not loaded much (I managed to fry my old Sabine Tuner), so I would test the voltage of any wall wart (under load) before hooking it up to my pedals.
Andrew.
Paul Marossy
Quote from: electrosonic on February 15, 2011, 05:03:17 PM
Andrew.
Yes, good advice. Or use a voltage regulator which bumps it down to the voltage you need without worrying about damaging your stuff.
