OH NO MY EHX METAL MUFF ACTIN UP HELP
Started by ultran8, February 14, 2011, 07:48:44 PM
ultran8
SO I TURN ON MY PEDAL BOARD AND IM LOSIN VOLUME THRU IT . BOILED DOWN TO THE EHX METAL MUFF . IT LIKE ITS NOT TRUE BYPASSING WHEN IT OFF . WHEN I KICK IT ON EVERYTHING IS COOL THE SAME OLD GREAT DISTORTION  . I WAS UNDER THE ASSUMPTION IT WAS TRUE BYPASS BUT WHEN I UNPLUG POWER I LOSE SIGNAL . SHOULD I TRY PUTTIN A NEW SWITCH IN IT OR JUST CALL EHX. ANY IDEAS OR SIMILIAR PROBLEMS FROM ANY OF U GUYS.
CynicalMan
Caps Lock stuck?  ;)
You can find the schematic at http://img130.imageshack.us/f/metalmuff.jpg/
It is buffered bypass, not true bypass, so check out the circled buffer. Of course, if it's still under warranty, get it fixed at your local EHX dealer.
ultran8
THANKS MAN ILL GIVE IT A LOOK SUCKS ITS ALL THIS MICRO CRAP NOW THANKS ILL GIVE THAT A TRY OR C HOW MUCH FIXIN IT IS FROM EHX IF I CANT HUNT IT DOWN OR BUILD A BYPASS SWITCH FOR IT AND LEAVE IT RUNIN ALL THE TIME. THANKS AGAIN ILL LET U KNOW WHAT COMES OF IT.
