AC powered pedals
Started by yeeshkul, February 21, 2011, 09:04:08 AM
yeeshkul
Whammy is AC powered. Is there any reason (apart from that you can't burn it by switching polarity) for powering pedals from AC power source?
CynicalMan
- You can make sure that the pedal is properly regulated with the voltage it needs
- The wall warts are cheaper
- It's easier to set up a bipolar supply
- It's easier to set up a voltage multiplier
In short, it's easier to makes sure your pedal gets what it needs without the end user blowing it up.
Hides-His-Eyes
How many burnt out pedals are there in the world due to those whammy supplies?
Here's a thing: yamaha magicstomp. Give it DC and the processor, LED etc work but you get no audio because the op-amps are supposed to be on bipolar supplies!
earthtonesaudio
Whoever said, "you can't fool-proof anything, because fools are so resourceful" was so right.
CynicalMan
Quote from: Hides-His-Eyes on February 21, 2011, 09:46:29 AM
Is that Digitech's problem?  ;)
I meant easier for the company making the pedal. Of course, the main issue will always be that thing between the strap and the guitar.
