100k Linear dual-gang pots
Started by eddie_bowers, March 22, 2011, 11:42:27 AM
eddie_bowers
I have been trying to find some with no luck.  SmallBear lists them, but says they are out of stock.
Anyone know where I can find Alpha (or similar) 100k Linear dual-gang 16mm pots?
jdub
Tayda and Futurlec both have them, and cheap, too.  Drawback is that they are not solder lug.  Still very usable, though- just solder wire to the pins.  :)
A boy has never wept nor dashed a thousand kim
aflynt
The great dual gang 16mm solid shaft 100k linear potentiometer crisis of 2011! :)
I've been looking recently as well for a Klone build I'm doing. These were the closest I've found:
Smaller D-Shaft Alpha:
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV122F-20-15F-B100K/?qs=sGAEpiMZZMtxdMMi52izylYRrYJAt1ntPTMiTp5U3d0%3d
Larger Solid Shaft Alpha:
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV24BF-10-15R1-B100K/?qs=sGAEpiMZZMtxdMMi52izypa54xBHd143VE2AEAmWU%252b0%3d
-Aaron
eddie_bowers
eddie_bowers
BTW, Small Bear responded to my email and said they will have some in stock next month.
