Ultra Flanger problems
Started by Bassisst90, March 25, 2011, 05:45:02 PM
Bassisst90
Hello. I have a huge problem with my John Hollis Ultra Flanger...It doesn't flange. I get a signal bypassed and when in effect but it doesn't flange and the knobs and odd/even switch does nothing. I've checked all the values and they're consistent with the values of the components listed. I thought maybe it was a chip problem and I tried to exchange chips, but it didn't do anything. The voltages I got were:
U1
1- 8.64
2- 0
3- 5.91
4- 0
5- 7.72
6- 7.16
7- 8.71
8- 9.39
U2
1- 9.39
2- 2.95
3- 6.83
4- 0
5- 0
6- 4.98
7- 8.69
8- 8.69
U3
1- 0.34
2- 0.34
3- 0
4- 0.34
5- 0
6- 4.98
7- 0
8- 0
9- 4.98
10- 2.99
11- 4.98
12- 2.99
13- 0
14- 4.98
15- 2.99
16- 0
U4
1- 0
2- 0
3- 4.98
4- 4.98
5- 0
6- 0
7- 0
8- 0
9- 0
10- 0
11- 0
12- 3.51
13- 0
14- 4.98
15- 0
16- 4.98
U5
1- alt.
2- 3.80
3- alt.
4- 0
5- 3.8
6- 3.82
7- alt.
8- 9.39
Anyone have an idea as to why it is behaving this way?
Bassisst90
So, I decided I'd try and see if I had any cold solder joints, and tried to reheat them. Now I get a metallic noise as I turn the regen knob, and if I turn it too much it becomes metallic feedback. Still no actual flange. Anyone have any ideas?
Thomeeque
#2
Quote from: Bassisst90 on April 07, 2011, 01:04:11 AM
I assume, that voltages at U4 look different now than in the first post (e.g. 14 & 15 are now close to 9V etc.)..
Problem is probably somewhere between LFO output (pin 7 of U5 = U5b output) and VCO input (pin 9 of U4), because rest seems to be working. Set slowest RATE, maximal SWEEP and maximal MANUAL and measure alternating (LFO) voltage on it's path from pin 7 of U5 to pin 9 of U4. It gets lost somewhere there.
T.
Do you have a technical question? Please don't send private messages, use the FORUM!
Bassisst90
Thank you so much! I found that I had a cold solder joint on r23, now it works like a champ. Sounds funky. Thanks a lot again.
Thomeeque
Bassisst90
Okay. Now I seem to be having a strange problem with the effect. The flanging works fine, its just that If I turn the regen pot from 3 o'clock on it gets this intense oscillation. I don't know how to get rid of it. I tried adjusting the trimpots but that didn't seem to help. Anyone run into this problem?
