Two Diodes Together
Started by shiner_man, March 30, 2011, 08:18:12 PM
shiner_man
I'm putting the following vero layout together and I can't fit the two diodes through the same hole:
Can I just solder them together end to end?
rousejeremy
www.jeremyrouse.weebly.com
shiner_man
Quote from: rousejeremy on March 30, 2011, 08:21:38 PM
yes
Word.  I guess this is what's known as in series in the business?
Thanks.
phector2004
why are you doubling the diodes in parallel?  ???
I don't think the voltage drop changes if they're not in series... Are they supposed to be in series?
Also, you might want to have a look at the jumper connecting to C7... doesn't seem to join anything
EDIT: Nevermind...
rousejeremy
I've built this layout. http://www.youtube.com/watch?v=UdKH1658XRo&feature=channel_video_title
Use shielded wire on the inputs and keep the lengths as short as possible. It can have an annoying high pitch oscillation when the drive and glass controls are maxed.
shiner_man
Quote from: rousejeremy on March 30, 2011, 08:32:28 PM
Thanks for the tip.
shiner_man
Forgive my ignorance but what exactly is oscillation?  I just finished building this and I get a slight hum at higher gain settings but
I though this was expected with almost every overdrive pedal.
digi2t
Maybe turn them 90 deg, put them on the same trace, and make a cut under each (example; C6, but twice, back to back). But you'll have to rearrange your layout somewhat.
Cheers,
Dino
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Quackzed
oscillation is usually a high pitched squeel or whistle, not unlike mic feedback... it can happen for different reasons, but generally speaking it usually pops up when you have very high gain. usually its a symptom of a powerfully amplified signal bleeding into another -more sensitive- part of the circuit; like the input....
shiner_man
Quote from: Quackzed on March 31, 2011, 04:03:23 PM
Oh well I'm not getting any of that.  I guess I didn't do too bad!
