One post, One component - An experiment
Started by phector2004, April 02, 2011, 11:39:26 AM
phector2004
I figured its easier making an oscillator with a bipolar power supply, but not everyone has charge pumps in their stash, and it's only saving about 2 or 3 components needed to run an opamp from 9V to ground.
I guess it's a good candidate for removal, then. The 1N4147 diode was a head-scratcher too... if anything, who not use a 1N4148  ???
I like the LFOs. Fig 2 looks simple, uses both opamps in the TL072
CynicalMan
The diode is reasonable for what Alex wanted to do, and any of the normal silicon diodes would work fine. However, I wanted to open up options for people. So, the LFO could be used as a switch or it could be used to drive the FET for a tremolo. Alternatively, that allows us to use the stage as an SSRP by connecting the 100k pot to ground on one side, power on the other, and with a cap from the gate to the source. We also might be able to switch between the tremolo and SSRP.
Quackzed
phector2004
Here's the latest version
Can't update too much these next few weeks cause I've got a ton of studying with finals.
Cheers,
Phil
Skrogh
I'll chime in, this looks interesting!
10k resistor to output of the LFO op-amp.
(Also please keep the inductor there, did a simulation in LTspice, it creates a nice resonant lowpass-filter with a cutoff around some 3kHz if I remember correctly - but only resonant on the negative side.)
I'll be back on the next page  ;)
phector2004
#65
Sounds interesting. Any chance you can post a screencap if you get it working?
EDIT: should we just throw in the whole LFO (no. 2) as one "component"
Just this once  ::)
earthtonesaudio
I told my coworker about this and he said there ought to be a Zener diode in there somewhere.  :)
phector2004
Screw studying for today...
I tried and succeeded in adding a zener  ;D
Hope you like it!
earthtonesaudio
Somebody ought to add a second 10u cap from pin 5 of the 1044 to GND so we have bipolar power already.
Not me though.  I already used up my turn.  :)
phector2004
Honestly, where does the zener go?
I've never used them before...
The 1044 is in limbo right now... I don't know if it'll be used
can i add an led and 470r from pin 1 of the 072 to ground....it worked on my phase 45 as a rate lfo indicator...
whether it will on this im not sure!.. :icon_wink:
phector2004
Sounds good
Did adding it change anything at all?
alparent
#73
OK I would like to make this really interesting by adding a SAD1024.
Steben
22n cap in series between the bottom of the 10u cap and ground in the LFO  ;)
Skrogh
Did some simulations back at post #68:
This is with a +1/-1V sinus input at 220Hz
This with the 0r set to 100k
phector2004
 :o
Well I'm baffled... Looks cool though, maybe I'll pick up an inductor from the local place when I'm done exams, see what it sounds like with a guitar signal
Skrogh
You might want to put in a buffer in front of the circuit, if you are going with the current schem...
Good luck with your exams  :)
phector2004
I'm back!
Forgot to order the less common components needed to build this, but I think I can test it out with similar components
I've got a 12V transformer from a pair of speakers and another unmarked transformer I yanked out of an RF booster, so maybe I can try those out. No idea what the inductance will be, but if they sound any good, I'll try measuring
Any ideas as to which winding makes a more suitable wah inductor? (Or if power transformers will work at all!?!)
