I feel silly for asking this but is there a simple way to test a buffer without-
Started by jimmybjj, April 03, 2011, 11:47:47 AM
jimmybjj
long and short cables? I just made my first layout in eagle (complete layout beginner)and I choose a simple buffer. I have no need for a buffer as I don't use a ton of effects or long cables, I just needed something very simple to layout? I made the layout and built it and it passes signal but my ears can't tell if there is any change to the signal if any. Is there any way I can test it other than whats mentioned above? Thanks for any help.
skrunk
this is probably a dumb answer, but maybe stick it between a wah and a fuzz face and see if you can hear a difference.
if it's passing signal and your voltages check, out its probably working.
JKowalski
It's a buffer. It's not supposed to do much. If it passes a signal and you cant hear much of a difference (i.e. no weird distortion, no significant volume changes), it is doing its job.  :icon_biggrin:
merlinb
You could stick a small capacitor -about 470pF- in parallel with the output signal. That would simulate an extra 5m of cable or so. Then try the same thing without the buffer and see the difference.
jimmybjj
Quote from: merlinb on April 03, 2011, 02:37:03 PM
Thanks so much for the response everyone. Merlin, that worked out perfectly. Pretty apparent that the buffer is working.
bluesman1218
Very cool, Merlin, very cool!
It's all about the tone!
Steve
POPA - Plain Old Power Attenuator AVAILABLE for PURCHASE soon!
Silvertone 1482 rebuilt - switchable Tweed, tube reverb, Baxandall + / Little Angel Chorus build, tons of Modded pedals
