Orange squeezer - Bass mods-Need help
Started by liagasg, April 09, 2011, 06:15:39 AM
liagasg
http://www.tonepad.com/project.asp?id=5
I want to build this compressor for a friend. He plays bass.
The mods say to replace 2 capacitors.
The capacitor connected to the diode is pretty obvious.
But, can you help me identify the output capacitor 4.7uF which should be replaced with a 1uF?
Which one is that?
Here is the layout
http://www.tonepad.com/getFile.asp?id=11
Warlord Custom
Mike Burgundy
IC numbers on the schem and on the layout differ - the 4558 is a dual opamp, but you're only using one. Opamp "A" (pins 1,2 and 3, as per schem) is not used. Opamp "B" (pins 7,6,and 5 as per layout) is used instead - find the 4.7uF that is connected to pin 5 on one end, and to the 10k level pot on the other, that's the one.
Renegadrian
yes ony one half of the IC is used - I use the OS on bass stock and it works good!
vendettav
hey guys planning to build this here as well. for guitar, I have a TL071. giving the OS uses half of 4558 could i put TL071 instead? wouldi need to change anything in there? or how would i wire it?? :)
check my music HERE
Shredtastic psycho metal!
Mike Burgundy
pinout is different (google for datasheets on 4558, TL072 and 071 and compare - 4558 and 072 are interchangeable, 071 isn't - single opamp instead of dual)
The layout in the tonepad file won't work for that - you'll have to make your own. Aside from that it'll be just fine. Just make sure all inputs, outputs and power connections match up.
vendettav
check my music HERE
liagasg
Warlord Custom
