AMZ Mosfet booster Vero layout ??
Started by HOTTUBES, April 23, 2011, 12:16:05 AM
HOTTUBES
Has this vero layout been verified to be working 100% !
Cause i built one and i can't get it to work properly , it sounds crisp & clean in by pass
but when you turn on the pedal it goes quiet & looses gain , i have use all the right
parts to the best of my knowledge , the only part that was different was the gain pot ,
it calls for a 5k linear , but i'm using a 5k log , not sure if that may be an issue ?
Also , i checked my voltage at the Drain of the BS170 , and it showed 4.05 volts ?
is that low ?
Thanks for any help !! :icon_redface:
kungpow79
That layout works.  Have built several.  The pot is fine.  Socket the transistor and make sure its the right orientation.
HOTTUBES
i have looked at several layouts to make sure they are showing the same orientation as my layout is , and checks out
correct , i replaced the BS170 with another just to see if that made any difference , but still no dice !
4.05 v/dc at the drain , is that a bit low , would that be it by chance ?
I have check over all my solders , and components , off board wiring
etc ....i'm stumped  :icon_confused:
HOTTUBES
#3
Early this A.M i got a PM sent from me from Jack Orman on the problem with this build ....
His instructions were to reinstall the mosfet in the oposite order , so i warmed up my
iron this morning and gave it a shot , and sure enought if he wasn't spot on with his
tech. tip , it now works 100 % !!!    And on top of that is sounds pretty good !!
Thank you  Jack !!
Case closed ........
HOTTUBES
Quote from: kungpow79 on April 23, 2011, 01:10:54 AM
Looks like you were right as well .......
Thanks !
