Safer breadboard power supply
Started by phector2004, May 01, 2011, 07:03:15 PM
phector2004
Hi everyone,
Just wondering if there's a way to limit the current going to a breadboard. I do my best to prevent shorting on the board, yet almost started a fire last week when I left my project to grab a bite. Even though I had disconnected the battery, the red lead somehow made its way to the audio jack sleeve. Came back to find a burning hot battery and yanked it out of the board right away. It's voltage dropped from 8.75V to 5.6 while I was gone  :icon_frown:
What would be best way to limit the current in case of a short?
A 9V regulator and a 12V adapter?
A resettable fuse?
A low current slow-blow fuse?
ayayay!
Other than rigging something up to disco your circuit when you stand up, a-la riding lawn mower seat, I don't see much you can do.
Look, you're prototyping.  You'll have to start thinking safety first.   ;)
The people who work for a living are now outnumbered by those who vote for a living.
phector2004
I actually get off the John Deere to push it when it gets stuck in the mud  :icon_biggrin:
Can't do that with the new ones!
blooze_man
The easiest thing to do would be to just disconnect both battery leads and move it away from the breadboard.
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
Quote from: phector2004 on May 01, 2011, 07:03:15 PM
Lots of ways. Some of them even practical and efficient.  :icon_lol:
QuoteWhat would be best way to limit the current in case of a short?
This one gets my vote, particularly if you use the 78L09 or LM317L regulators which are internally limited to about 100-150ma without any other messing with them.
QuoteA resettable fuse?
Maybe. It's hard to get them small enough, though. And tolerance is a huge issue.
QuoteA low current slow-blow fuse?
I would not.  You'd have to replace a fuse every time, wonder why it blew, and in general fuss with the uncertainty of what current it blows at, not a trivial thing to do.
Things you didn't mention include active current clamps made from a couple of transistors.
Try the 78L09 or LM317L.
phector2004
Thanks, R.G!
I figured it was the simplest "safe" option.
Quote from: blooze_man on May 01, 2011, 08:27:27 PM
I do do that when I'm not tinkering, but when you're debugging a circuit on the breadboard and put it in the wrong hole, you sometimes don't notice wires overheating till they stink up the room! I've already cooked an LED and a jumper from shorts, as well as my battery last week. I'm trying to keep it to a minimum!
spargo
I don't use batteries, just a 9V DC adapter.  I believe it has built in protection for shorts, etc.  Just in case, I simply unplug it when I leave.
