Fuzz face and dunlop wah input impedances?
Started by knealebrown, May 02, 2011, 12:07:28 PM
knealebrown
Hi guys,
I know they are low but does anybody have figures for these please? ive been looking online with no luck  ???
Regards
Kneale
''99 problems but a glitch aint one!''
yeeshkul
It among the others depends also on the transistors used. I figured out 7k for typical Si FF.
CynicalMan
LTSpice says 33k for a Ge Fuzz Face and 720k for the Original Crybaby. Still, it would be better to test these out.
Paul Marossy
If you have both pedals, you can use Craig Anderton's Impedance Tester and it will give you an approximate number. It will give you some idea of what is going on.
http://www.diyguitarist.com/PDF_Files/ImpedanceTester.pdf
yeeshkul
Quote from: CynicalMan on May 02, 2011, 04:32:49 PM
That would be the buffered CB, 720k is fairly solid input imp.
CynicalMan
Oops. That wasn't the buffered Crybaby but I calculated it wrong. The Crybaby's around 87k.
Paul Marossy
Quote from: CynicalMan on May 03, 2011, 04:00:26 PM
That's pretty bad. You'll definitely notice anything under 200K. The worst tone sucking pedal I ever had was a vintage Vox wah pedal. I true bypassed that thing as soon as I got it!
