some questions
Started by vendettav, May 03, 2011, 02:40:29 PM
vendettav
hey gyus, so I was messing around with the NPN boost (the beginner project) on a breadboard and it didn't work! nomatter how hard i tried. i did everything, checked it again and again, swapped the trannies and whatnot. the voltage was wrong i guess but i never found why. the gain pot didn't work either. i got at the point where i tried an unlabeled tranny and it gave me some distortion kind of thing but would crackle in the end of the notes and as i said the pot did no difference.
so i tried a LPB-1 booster. and while the thing worked fine the thing seemed to be clipping in side, not my amp. ok whatsoever. the question is is there any nice mod to an LPB-1 to fill up my drilled enclosure's empty hole. it's a 2 pot enclosure so i'm thinking of one pot and one switch.
any ideas are appreciated. also maybe there are some other, better boosts? i can't get my hands on any mosfte, so it's gotta be simple, npn or fet and not include many transistors please?
V
check my music HERE
Shredtastic psycho metal!
blooze_man
Tim Escobedo has a couple easy transistor boosts. Check out Boost-O-Rama and the Utility Boost pages.
http://folkurban.com/Site/GuitarEffects-681.html
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
digi2t
runoffgroove's Omega. Built one into my Skyripper, in place of the Rangemaster circuit, it's great. Like a Rangemaster, but with a tone knob. Actually, almost nails the Rangemaster tone as well.
Circuit is here; http://www.runoffgroove.com/omega.html . I can cut out the Omega part of my Skyripper vero, and post it if you like. Low parts count, but there is a mod at the end of the circuit to prevent the Master pot from producing any scratchy noises when being turned. If you copy the diagram directly, you risk a noisy pot. Got the fix from John Lyons. Works like a charm.
2 pots, and a switch. Should fill out your enclosure nicely.
Cheers,
Dino
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
vendettav
ah either of those seems out of my reach. the parts i mean. pots are quite a hassle here but ill try to get the 250k pot for boost-o-rama
as for omega. I guess you can omit the mosfet buffer by placing a 100k from the Drain to the output pot bypassing the 33k and 68k resistors. I'll be having a TL071 buffer in the box always on so i dont need an additional buffer (especially when i can't get a mosfet). the question is where shall i put the buffer: at the input or the output?
and finally is it possible to omit the range knob (i don't think I can get 500k pot here) and put there a full signal boost/fat(or treble) boost switch?
and trimpots here being about 2 bux each (!) I'll rather put a pot there and bias it to my liking then replace the pot with a fixed resistor.
Ima try doing all this in LTspice (still trying to get the hang of it  :icon_rolleyes: ) but answers here might be more than helpful :)
check my music HERE
Hides-His-Eyes
where are you? Tayda ship EVERYWHERE....
Perrow
vendettav
I know I just don't have a credit card. ordering via paypal is a pain in the ass in my country so im waiting for some more stuff to build up in my to buy list so that i can buy it all at once you know :)
anywaysi jsut breadboarded the Stratoblaster from GGG and it sounds really neat I'm loving it! now the thing is, i have 2 holes on the enclosure for pots. i want to put a switch in there, will this make much sense with stratoblaster? http://www.muzique.com/news/mini-booster-fat-and-fatter/
check my music HERE
