Famous tube boost schematic, need values
Started by LOLAND, May 07, 2011, 03:54:14 PM
LOLAND
http://s47.photobucket.com/albums/f191/krinor/?action=view&current=Valvecasternylayoutmkabler.jpg
I've seen this schematic talked about countless times, but I can't find the values for the resistors and caps. Does anyone have the key that goes with this image?
blooze_man
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
LOLAND
Fox
I dunno the exact values but  its almost a standard valve preamp, so the caps C1 C2 C3 will be ruffly 22n, R1 R4 will prolly be 1M, R2 R3 can be 100k -330K...try 100K first. C4 can be 100n ..trial and error here, use what suits best.
cheers
Fox
Quote from: LOLAND on May 07, 2011, 04:08:25 PM
That is a different schematic.
Compare the pin and part numbers on the schematic in the link blooze_man gave with what you've posted, it's the same thing just drawn differently.
You pointed to a lay-out.
Blooze pointed to a schematic.
They show the SAME circuit, different ways, and even the same part numbers (C2, R4, etc).
