squaring a guitar signal
Started by dylar, May 13, 2011, 10:25:40 PM
dylar
Is there a way to square a guitar input signal so that it can be fed into a digital IC? Specifically, the CD40106?
I have found a few circuits that square signals, but what is the easiest / quickest way?  Doesn't need to be hi-fi
iccaros
??? a square audio wave is a distorted wave. If you just want to set a trigger, don't worry about square waves, The chip will trigger when the signal rises and falls.
electrosonic
REad the stompboxology newsletter on Frequency Division & Subharmonic Synthesis -Stompboxology  Vol. 13, No. 3
lots of good ideas
http://moosapotamus.net/IDEAS/stompboxology/FreqDiv_SubharmSynth.htm
dylar
I want to send instruments, a keyboard or guitar, through a small synth I have made from a 40106 (schmitt triggers).
Would it be possible to hook up an envelope follower to the voltage in of the triggers?  I wonder what that would do.
Basically I'm just trying to figure out how to send any signal through this synth.
