Jawari Transformer question
Started by CodeMonk, May 14, 2011, 08:08:02 PM
CodeMonk
I went to build a Jawari the other day.
I started without really looking at the required transformer.
The Radio Shack one is a not go.
Around these parts, I'm known as the guy that will take busted electronics off your hands.
I have a bunch of old TV's, stereo's etc.
Many of them have small transformers about the size of the Radio Shack one, which I am guessing is also the size of the one required by the Jawari.
How would I go about testing these to see if any are compatible with the 42TM018?
Would it just be as simple as measuring the resistance of the windings?
Paul Marossy
Quote from: CodeMonk on May 14, 2011, 08:08:02 PM
RadioShack doesn't sell tranformer with those specs. Physical size of the transformer is not a reliable indicator of anything. A 10K:10K transformer is not a common size from what I can tell, you're not likely to find one in some old electronic device. It's a lot easier to just buy a few from Mouser, they're not expensive at all.
CodeMonk
Quote from: Paul Marossy on May 14, 2011, 08:43:48 PM
Yeah, I know its not common and they don't cost much, and I know RS doesn't sell them.
I just want to know if there is a simple way to test the many transformers I do have in the off (and rare) chance that I may actually have one already.
I do plan on ordering a few from mouser once I pay all my bills this weekend to see how much I can allocate for those as well as other parts.
Thanks.
Paul Marossy
#3
Quote from: CodeMonk on May 14, 2011, 08:53:31 PM
Thanks.
Oh, I see. I don't think there is a way to directly measure them. I just checked the DC resistance of one of my 42TM018s (10K:10K), and they only measure 500 ohms.
iccaros
if you can put a known VC voltage on one side, and read the other, it will give you the stepping.. or Ratio
For 10K:10K is a one for one transformer same as a 1:1
so put 10 volts in and read the other side. if you get 10 volts its a 1:1
if you get 100 its a 1:10
if you get 1 its a 10:1
and so on..
use low voltage if you do not know the ratings.
CodeMonk
Thanks guys.
In the meantime though, I'm building a "Pocket" theremin.
