Can anyone identify this component?
Started by Flooflox, May 15, 2011, 11:54:32 AM
Flooflox
There is something attached to the resistor. It's from that electric blanket controller I was asking about earlier.
Brantford, Ontario
vendettav
check my music HERE
Shredtastic psycho metal!
Meanderthal
 Thermister? Diode? Parakeet leg band? Gotta see thru the shrinkwrap to know...
pjwhite
I'm guessing it's a crimp, used to attach the wire to the resistor leg, covered in heat-shrink tubing.
digi2t
I'm with Meanderthal... parakeet leg band seems more likely.  ;D
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Brossman
my guess is some kind of protection diode, as it is in series with the resistor...
Gear: Epi Les Paul (archtop) w/ 490R in the neck, and SD '59N in the bridge; Silvertone 1484 w/ a WGS G15C
Still a tubey noobie. Been doing this a while, and still can't figure much out, smh.
StereoKills
Looks to me like it's probably a crimped connection covered in heat shrink.
Only one way to find out though. Take off the heat shrink.
"Sometimes it takes a thousand notes to make one sound"
teemuk
What function is the resistor and the mystery component perfroming in the circuit?
Is it a function needing a thermistor?
Is it a function needing a diode?
Is it a function needing something else?
...Or is it just a high voltage node needing a shrinkwrap insulation to leads of the resistor?  ;)
Flooflox
Quote from: StereoKills on May 18, 2011, 08:02:45 AM
Well, got out the utility knife and discovered it was indeed a crimped connection under there. Kinda felt like Geraldo Rivera opening up an empty Al Capone vault.  :D
Brantford, Ontario
Earthscum
Quote from: Flooflox on May 19, 2011, 11:39:41 PM
Nicely put! Lol... Been there, for sure. Got myself all worked up over a shrink wrapped sloppy solder joint.
