GT108V Transistors?
Started by A.Gillies, May 18, 2011, 08:40:18 AM
A.Gillies
The datasheet says Hfe is 60-130, good for a Fuzz Face. Is there anything else that I have to look for on the datasheet? Has anyone had any experience with these transistors? Thanks.
It Goes To Eleven
LucifersTrip
Quote from: A.Gillies on May 18, 2011, 08:40:18 AM
I haven't used those, but as I wrote in the other post, my experience has been that most older transistors fall into the lower end of the range.
So, I wouldn't be surprised if you get most in the 50-90 range, which would be only good for Q1. Hopefully, you'll get a good amount in the 100-120 range.
I bought another Russian lot with a range 80 - 150. EVERY SINGLE ONE was between 59 and 88
good luck
always think outside the box
A.Gillies
Quote from: LucifersTrip on May 18, 2011, 11:32:19 PM
good luck
Thanks. I'll let you know how it goes.
It Goes To Eleven
A.Gillies
good luck
The transistors arrived a few days ago, and I was pleasantly surprised. The lowest gain I've seen so far has been 70 and the highest so far has been 110, most are 80 to 100. They sound pretty cool as well. When I first tried them in a Fuzz Face I thought they were noisy, but after a few minutes the noise went away. I had been handling the transistors right before I tried them, so does this have something to do with their sensitivity to heat? Anyway, I'm just glad it worked out, and I definitely recommend them to anyone who's thinking about trying them.
It Goes To Eleven
brett
Hi
there are several models of *very* good Russian devices - 308s, 313s, 311s.
Now add GT108Vs. Good research.
thanks
Brett Robinson
A.Gillies
Quote from: brett on June 06, 2011, 07:38:42 PM
Hi
thanks
Thank you!
It Goes To Eleven
DDD
Brief translation from the Russian datasheet:
GT108 (ГТ108):
- Fmax (common base) Ucb=5 V, Ie= 1 мА:
ГТ108А.......................................................................0,5 МHz;
ГТ108Б, ГТ108В, ГТ108Г ...................................................1МHz;
- Saturation C-E voltage, Ic=50мА
Ib=5 мА..................................................................3 V;
Small signal gain, Ucb=5V, Ie=1 мА:
Т=293К:
ГТ108А................................................................20 – 50;
ГТ108Б.................................................................35 – 80;
ГТ108В...................................................................60 –130;
ГТ108Г...............................................................110 – 250;
Т=328К:
ГТ108А.................................................................20 – 100;
ГТ108Б.....................................................................35 – 160;
ГТ108В......................................................................60 – 260;
ГТ108Г......................................................................110 – 500;
Т=243К:
ГТ108А......................................................................15 – 50;
ГТ108Б.......................................................................20 – 80;
ГТ108В......................................................................40 – 130;
ГТ108Г........................................................................70 – 250;
- Leakage collector current Ucb=5v:
Т=293К................................................................10 uA;
Т=328К...............................................................250uА;
A.Gillies
Quote from: DDD on June 07, 2011, 04:40:41 AM
GT108 (ГТ108):
Т=293К:
Т=328К:
Т=243К:
Cool, Thanks.
It Goes To Eleven
skumberg
Thanks for the report. I have kept my eye on those but hesitated because of the low 10V maximum Ucb rating. Perhaps there is no need to worry?
