what does this schematic symbol mean?
Started by FWALS, May 23, 2011, 05:38:39 PM
FWALS
I'd like to build this, but I'm not sure what the  arrow with 'Vb' above it means.
Any help would be appreciated. Here's a link to the schematic
http://www.experimentalistsanonymous.com/diy/Schematics/Fuzz%20and%20Fuzzy%20Noisemakers/Analog%20Bit%20Crusher.gif
cloudscapes
it's a voltage reference. in this case half of the power supply generated by the two resistors and capacitor on the left. just connect all 5 Vb points together and you're good to go.
{DIY blog}
{www.dronecloud.org}
ayayay!
Wow!  I don't think I've seen a pedal with so few grounds...  :icon_eek: That alone begs it to be built.  Should be really easy!  What the heck is this anyway?  Something synth-y?
tiges_ tendres
Quote from: ayayay! on May 24, 2011, 10:09:21 AM
It's a sample rate reducer.  Kind of sounds like a ring mod.  I built one but was largely unimpressed.
Try a little tenderness.
ayayay!
I'm a derp.  I don't know what a sample rate reducer is unless it's one of those online mortgage calculators.
Gurner
They're there in spades... albeit virtual ones!
tiges_ tendres
Quote from: ayayay! on May 24, 2011, 02:25:15 PM
Sounds like this:
ayayay!
QuoteThey're there in spades... albeit virtual ones!
Oh yeah I know, I just mean the literal components to earth.  Don't see that too often in pedals.
EATyourGuitar
also fair to say that it can be called a sample&hold that goes up to audio rates. hence, therefor, hereto ::strokes beard:: why its a analog sample rate reducer and not the traditional analog>digital>analog converter with variable clock frequency.
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
FWALS
Quote from: tiges_ tendres on May 24, 2011, 01:03:28 PM
Hey what part did you use for the op amps?
MikeH
Quote from: ayayay! on May 24, 2011, 03:34:06 PM
They dont show it on the schematic, but you'll obviously need to ground the opamps.  It's really not that different than other designs of similar complexity.
tiges_ tendres
Quote from: FWALS on July 24, 2011, 09:27:05 PM
2 4558's  Any dual will do.
