First pedal help (LBP1 Boost)
Started by DonB, May 30, 2011, 06:36:20 AM
DonB
Ok i build the EH LBP! from this vero. But had no 10k res so used a 4k7. Also the caps are ceramics instead of greenies.
It works, but has alot of grounding type noise
Would this be because of the caps? or is there something i need to do to ground it (its not in an enclosure yet).
The Q1 is - 2N3904
Also with a 3dpt switch how do i wire an led to it?
- - -(this one)
DonB
Could i put ground out from F7 on the board (bottom right)?
twabelljr
The whole bottom row (row F) is ground if that is what you are asking, yes.
Shine On !!!
DonB
#3
Thanks for that. I thought it was. Anyway i just rewired it differently and it works fine now.
Wired with a 3dpt switch and led, changed a few wires around (bassed of a different diagram) and its great.
DonB
Gave the pedal a proper go today. It works BUT has alot of fuzz on the sound, instead of being clean?
glesconz
Hi, ive built this and it sounds good...if it sounds fuzzy maybe its a poorly filtered power supply. If its a power supply you're using, is it regulated (puts out 9v at the tip)?  Cheap wall warts also have notoriously bad filtering which can cause fuzz. Maybe throw a battery in and see if it is your power source..
Cheers
Glenn
ayayay!
#6
QuoteBut had no 10k res so used a 4k7
So get another 4.7k and add it to the other one in series to get it closer to 10k.  You may be nailing that tranny w/ too much current.
Also be sure you haven't reversed the pinouts of the transistor.
Quoteor is there something i need to do to ground it (its not in an enclosure yet).
Yes, box it up in an enclosure.  It's going to hum like mad without it.   ;)
The people who work for a living are now outnumbered by those who vote for a living.
vendettav
oh yeah i also double up the walwart hum. if it's the DC buzz you are hearing than you can try the little trick of running a 100uF cap from positive of the power to the ground.
check my music HERE
Shredtastic psycho metal!
DonB
#8
Ok forgot to mention that its boxed up and has no grounding problems. I am running of 9v battery, but still has the wierd fuzzy/bassy sound.
Will try the extra 4k7 resistor (can this really make that much difference) and see how that goes. Im pretty sure everything is in the correct spot other than the small resistor.
Also as i play a note on the gutar the led gets brigther, but then dulls down when not playing? The more notes i play the more strobe type effect it has.
ayayay!
QuoteAlso as i play a note on the gutar the led gets brigther, but then dulls down when not playing? The more notes i play the more strobe type effect it has.
Whoa red flag.  You've got AC in your DC!  (See a doctor...)
Okay so I'm guessing you're using a 3PDT?  You can't use an LED w/ a DPDT as shown, sorry.  In either case, disconnect all LED connections and then measure your output jack to see if it has DC on it.
EATyourGuitar
I want to know exactly how he did it so I can make fuzz boxes out of the stack of LPB pcb's I have. :icon_smile:
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
DonB
I used this wiring diagram for the LPB1.
DonB
Ok this might be the problem...
I have the Black negative batt lead going to the 3dpt instead of the positive (red) and the posivtive going to the board. so i need to change the black to the in sleeve then add a wire from the board to the switch. Will do it tonight and see how it goes.
euronymous0001
http://gaussmarkov.net/wordpress/thoughts/wiring-up-a-1590b/
ground going to the 3pdt instead of +, LED connected to + (DC jack or on the board)
also, input of the fx is grounded if on by-pass
blooze_man
I think the 430k and 43k resistors need to switch places.
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
DonB
Quote from: blooze_man on June 01, 2011, 07:55:26 PM
You think or they do need to be switched?
blooze_man
twabelljr
#17
http://fuzzcentral.ssguitar.com/schematics/lpbschem.gif
This and other schematics show the layout to be correct. Higher value R from 9V to base and lower value from base to ground.
Shine On !!!
blooze_man
Aww crap. That's what I get when I trust my powerful memory.   :icon_lol:
Govmnt_Lacky
If you switch around the wiring to the LED then that SHOULD eliminate the fuzz and the "brightness when playing" issue.
You need to wire one side of the LED, via the resistor, to your V+ input. Then, wire the other side to your 3PDT (V-/Ground)
Good Luck  ;D
