Help with pots
Started by carlosgg6, June 03, 2011, 05:43:25 PM
carlosgg6
Hi, first at all, i wanna introduce myself, I'm Carlos from Costa Rica (is a country, google it)
Now  my problem, In my country is very difficult (almost impossible) to find a 100k log pot, you can only get the 250k and 500k ones.
Also you can get 100k but linear.
My question is, can you use a 250k log pot instead of the 100k log pot.
Or, can you "mod" a 100k linear into a 100k log.
Thanks for your help
Trust me, im a doctor
carlosgg6
thank you
but to be clear, if i want a 100k log pot, i need to solder a 20k resistor between the center "pin" to any of the other two 2 "pins"
i just want to say thanks, and sorry my english level isn't huge, and google translator sucks :P
There are a few other tricks you can do with pots as shown in:
http://www.diystompboxes.com/smfforum/index.php?topic=91972.0
This shows the use of a linear pot to provide a non-linear amount of control suitable for a volume control (although it is not an audio or logarithmic taper).
In your original question, does the unit still work properly with a 250 K pot?  If so, use the 250 K log pot.
