18V Booster - Charge Pump Question
Started by jammybstard, June 06, 2011, 12:44:48 PM
jammybstard
I'm looking to build some sort of JFet Booster to drive my amps first valve.
I'd like a pure valve tone so I want clean boost with lots of head room, I'm thinking 18v Booster from a 9V supply Via a Charge pump!
As it seems to be tried and tested around here I was going to use an ICL7660SCPA voltage converter to make as common 9v supply into +/-9v and then tap across the + and - supplies to get 18v.
Fine stand alone! But thinking about it; If I'm now using the -9v as a pseudo Gnd and then I daisy-chain the supply onto another pedal (a regular 9v pedal) and then connect the two together with an interconnect, I would end up effectively shorting Gnd to -9v back through the interconnect! So that ideas out for starts
So what's the most common IC to use to double voltage without creating a negative voltageand doesn't put HF noise on the supply?
Death to the Intolerant
merlinb
There is a more sneaky way to get roughly double the headroom from a 9V circuit. And it doesn't waste power either:
http://www.diystompboxes.com/smfforum/index.php?topic=91629.0
Processaurus
LM1054 is what I use for voltage doubling, there is on board regulation as well, so you could boost the pedal supply to 18v and regulate it down to 15v, if you wanted it to be compatible with noisy power supplies.  That and unregulated doubling are in National's app notes in the datasheet, very simple.
jammybstard
jammybstard
Quote from: Processaurus on June 06, 2011, 02:15:28 PM
Is that number right Proc? I cant find an LM1054
merlinb
Quote from: jammybstard on June 06, 2011, 02:17:02 PM
Far too clever Merlin!
One opamp, three transistors (or two if you used true bypass)... not exactly the space shuttle in terms of complexity!
jammybstard
Quote from: Processaurus on June 06, 2011, 10:04:00 PM
Quote from: frequencycentral on June 06, 2011, 04:43:45 PM
LT1054: http://oh3tr.ele.tut.fi/~ftp/pa/cly10amp1/lt1054.pdf
Mos def:  LT1054.  Texas Instruments, not National.  Thanks.
Cheers, These seem either hard-to-find or overpriced in the UK! What do you pay for them where you are?
Dimitree
I use LT1054 too, but I don't understand how to regulate it, for example, to 15V. Any help? thanks
jammybstard
Tried this tonight:
seems to work great; So started work on the Booster
Processaurus
Quote from: Dimitree on June 07, 2011, 09:11:58 AM
Page 15, figure 20 in the datasheet I linked to has the circuit and equation to determine R2, you'd just put in 15v for Vout in their equation (the second one with Vref replaced with 1.21v and R1 being 20K)
Dimitree
#12
thanks,
and how can I regulate to -15, for example? the figure shows a VOUT and not a -VOUT like figure 19 (the VOUT is in modulus so I guess it will give -VOUT btw?)
Galego
Quote from: Dimitree on June 15, 2011, 07:56:46 AM
thanks,
To have +18/-18V, you need two cascaded ICL7660S, the schematic can be found in the datasheet. You can also look at the datasheet for the MAX1044. Make sure you get the 7660S and always connect pins 1 and 8 together, it boosts the frequency.
You don't need two ICL7660S, you can do it with just one.
http://www.geofex.com/circuits/+9_to_-9.htm
http://www.geofex.com/circuits/+9_to_33.htm
...getting higher voltage (and lower -ve voltage) is just a matter of adding more caps and diodes.
...or you can use a NE555: http://analogguru.an.ohost.de/001/schematics/Analogguru_SymmVoltMultiplier.gif
polaris26
Another idea to play with - if you have a low voltage/low impedance source (say 1k output impedance) feeding into a much higher impedance (say 100k or higher) input, you can get a fairly decent voltage boost by using a small audio transformer.  A 2:1 voltage (turns) ratio would yield a 4:1 impedance ratio, so if you have, say, a 1k output impedance, you would still have only a 4k output impedance which would be more than adequately low to feed into most guitar amp inputs.  A 3:1 turns ratio would yield a 9k output impedance and triple the output voltage, etc.  The frequency response may be limited in some noticable way, but it might also sound good, so you could salvage a small transformer and give it a try.  You might even get away with a small AC power transformer?
Dave
In the heart of the Poconos!
Dimitree
Quote from: Galego on June 15, 2011, 02:58:49 PM
thanks,
thanks but my question was about regulating the output voltage. I usually use charge pumps to get +18/-18 with no problems, but this time I need a regulated -15V, but figure 19 shows a positive regulation if I'm not wrong.
Processaurus
Quote from: Dimitree on June 16, 2011, 09:45:22 AM
thanks,
On page 17 there is a:
Figure 23. 100-mA Regulating Negative Doubler
merlinb
Considering the input headroom of your valve amp will be only about 4Vp-p max, one might ask why you need +-18V...
Back in the days of valves, Leo raised B+ voltages from 200V to 350V or 400V for more headroom.
IMHO, 9V 18V +/-18V(??) on tubes is just fooling yourself. Even the cheepest battery tube radios got 22V, any serious battery tube radio had 45V 67V or 90V supply. And these were not amazing-clean machines, but batteries were EXPENSIVE.
As Merlin says, your OUTput is presumably going into a guitar amp, with input overload of just a few volts. On that grounds, you could try lower voltage, even 10V, so the clipped output is in a right ballpark. However your tube has gain, surely 1:10 or 1:30, so now your tube's input overloads VERY easy, and hisses.
